Problems with using rosinterface - synchronous mode
Posted: 22 May 2018, 08:54
Hi all,
I am currently trying to sync my v-rep simulation with a ros-node written in C++. From the C++ ros-node, using the RosInterfaceHelper tool, I am enabling the sync mode and triggering the simulation every time I loop through my controller program in the node. So the C++ node loops the following commands:
enableSyncMode(true)
Run program - i.e., the controller
triggerNextStep(true)
triggerNextStep(false)
rate->sleep() -- (this rate is set to 20hz as the simulation is using 50ms)
rosSpinOnce()
To test that the node and the simulation are in fact synchronized I am running a small test where I increment a number in a child script inside the simulation that I publish to a ros topic. However, when reading in the C++ node the sequence is not consistent and is strongly dependent on the rate I use in the C++ node. If the rate is much higher than the simulation step, dt, then I will miss a lot of the numbers in the sequence. If it is set to what the simulation is running at (i.e, 20hz) it is better but still random (sometimes I read the same number twice and other times I am skipping a number).
Do you have any idea about what I am doing wrong?
Best Regards,
Mathias Thor
EDIT: One additional question: "Why is the ros::rate in the C++ node depending on the sim step size, dt, when the C++ node is triggering the simulation for every step?"
rosSpinOnce()
Best Regards,
Mathias Thor
