V-REP on Docker
gvgramazio
V-REP on Docker
Post by gvgramazio » 01 Aug 2018, 17:25
Hi, I'm trying to build a docker image with all the requirements to run v-rep and I have some troubles. This is what I have right now:
FROM ubuntu:16.04
RUN apt-get update && apt-get -y install \
      curl \
      sudo
# Replace 1000 with your user / group id
RUN export uid=1000 gid=1000 && \
    mkdir -p /home/developer && \
    echo "developer:x:${uid}:${gid}:Developer,,,:/home/developer:/bin/bash" >> /etc/passwd && \
    echo "developer:x:${uid}:" >> /etc/group && \
    echo "developer ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/developer && \
    chmod 0440 /etc/sudoers.d/developer && \
    chown ${uid}:${gid} -R /home/developer
USER developer
ENV HOME /home/developer
RUN cd /home/developer && \
    curl http://coppeliarobotics.com/files/V-REP_PRO_EDU_V3_5_0_Linux.tar.gz --output vrep.tar.gz && \
    tar -xzf vrep.tar.gz && \
    rm vrep.tar.gz
But if I run `./vrep.sh` in the V-REP directory I encounter an error of missing libraries. If I run `./libLoadErrorCheck.sh ` I have the following output.
	linux-vdso.so.1 =>  (0x00007ffdac474000)
	liblua5.1.so (0x00007fa23a8e5000)
	libqscintilla2.so.9 (0x00007fa239324000)
	libQt5OpenGL.so.5 (0x00007fa2390cd000)
	libQt5Widgets.so.5 (0x00007fa23889c000)
	libQt5Gui.so.5 (0x00007fa2380ef000)
	libQt5SerialPort.so.5 (0x00007fa237ed6000)
	libQt5Network.so.5 (0x00007fa237b45000)
	libQt5Core.so.5 (0x00007fa23740d000)
	libGL.so.1 => not found
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fa2371f0000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fa236e6e000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fa236b65000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fa23694f000)
	libc.so.6 This application failed to start because it could not find or load the Qt platform plugin "xcb"
in "".
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Reinstalling the application may fix this problem.
./vrep.sh: line 33:   543 Aborted                 (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
=> /lib/x86_64-linux-gnu/libc.so.6 (0x00007fa236585000)
	libQt5PrintSupport.so.5 (0x00007fa236317000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fa2360fd000)
	libicui18n.so.56 (0x00007fa235c64000)
	libicuuc.so.56 (0x00007fa2358ac000)
	libicudata.so.56 (0x00007fa233ec9000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fa233cc1000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fa233abd000)
	/lib64/ld-linux-x86-64.so.2 (0x00007fa23a7eb000)
	libgthread-2.0.so.0 => not found
	libglib-2.0.so.0 => not found
What dependancies I'm missing? I've found nothing on coppeliarobotics.com. If I solve these dependencies with
apt-get -y install libgl1-mesa-glx libglib2.0-0
V-REP doesn't run. The error this time is:
in "".
Re: V-REP on Docker
Post by coppelia » 03 Aug 2018, 06:47
Not sure... can you confirm that you have platforms/libqxcb.so present?
gvgramazio
Re: V-REP on Docker
Post by gvgramazio » 16 Nov 2018, 18:14
Sorry if I didn't reply to this message before but it wasn't on my subscriptions. I've solved the docker problem using the following docker file:
FROM ubuntu:16.04
RUN apt-get update && apt-get install -y \
  wget \
  libglib2.0-0  \
  libgl1-mesa-glx \
  xcb \
  "^libxcb.*" \
  libx11-xcb-dev \
  libglu1-mesa-dev \
  libxrender-dev \
  libxi6 \
  libdbus-1-3 \
  libfontconfig1 \
  xvfb \
  && rm -rf /var/lib/apt/lists/*
RUN wget http://coppeliarobotics.com/files/V-REP_PRO_EDU_V3_5_0_Linux.tar.gz
RUN tar -xf V-REP_PRO_EDU_V3_5_0_Linux.tar.gz
RUN apt-get remove -y wget
RUN echo 'export QT_DEBUG_PLUGINS=1' >> ~/.bashrc
RUN echo 'export PATH=/V-REP_PRO_EDU_V3_5_0_Linux/:$PATH' >> ~/.bashrc
It works fine except for one thing: if I start V-REP even in headless mode it gives me problems because there is no screen. This should be an issue due to Qt and a possible workaround is to launch V-REP with xvfb that fakes a screen.
I've loaded this on github and an automatic build on docker hub. Maybe it could be helpful to someone.
