modeling a rope with a changing length
vreprobot
Post by vreprobot » 26 Sep 2018, 08:05
I want to model a rope with a changing length .I used a prismatic joint but i cant find a remote api function to change joint range during simulation.
Is there a way to model such kind of rope? or is there any way to change the range of a prismatic joint using python?
Re: modeling a rope with a changing length
Post by fferri » 26 Sep 2018, 08:06
Hi vreprobot,
why do you want to change the joint range instead of working with joint position?
vreprobot
Post by vreprobot » 26 Sep 2018, 08:17
Because the rope is connecting two robots to each other. But when each of them moves the joint position changes and when it reaches it's max or min a force is applied to robots and they cant move any more. But sometimes after the joint reaches it's max position I want to make the joint range bigger so the robots can move.
Post by fferri » 26 Sep 2018, 09:13
Looks like you need to set a larger joint range in the first place.
You can apply forces/torques to a joint, and also define a custom controller with joint callback functions.
