Rotating sensor on robot
remblim
Post by remblim » 09 Oct 2018, 21:20
I got a robot wich moves around in the simulation, I would like to make a sort of scanning (rotating) laser sensor. The robot is moving and the wheels are nicely rotating but I'm not able to move the sensor positioned on top of a revolute joint. I tried Torque/force, inverse kinemetic and motion mode (although depreciated). Other thing I tried was position a small object (low mass primitive shape) as child of the revolute joint with then the sensor as child from primitive shape but strange things happen when the simulation starts.
I hope you guys can help me.
Re: Rotating sensor on robot
Post by coppelia » 10 Oct 2018, 07:27
for a sensor, you would typically not want to dynamically simulate it. So the rotating elements would be non-respondable and static shapes. The joint should be in passive mode. Then you can modify the angular position of your joint with sim.setJointPosition.
remblim
Post by remblim » 10 Oct 2018, 08:42
It works, thank you for the fast reply.
King regards
