Matthew Qi
Post
by Matthew Qi » 10 Oct 2018, 03:47
Hi:
I am recently running my robot in V-REP with Python, I run the simulation repeatedly by
connect_simulator, start_simulation,stop_simulation,disconnect_simulator
I found that the recording curves of joint positions in Graph would leap to a large value at start as show in picture
The consle message of vrep as shown
Warning: 'print()' now prints to the status bar, instead of the console (use 'print=printToConsole' to revert).
Lua runtime error: [string "CHILD SCRIPT Fbody_d"]:4: Invalid port number. (simRemoteApi.start @ 'RemoteApi' plugin)
stack traceback:
[C]: in function 'start'
[string "CHILD SCRIPT Fbody_d"]:4: in main chunk
So would you please tell me how to solve this problem?
Sincerely,
Matthew
- Site Admin
Post
by coppelia » 10 Oct 2018, 08:00
at simulation start, it can be that some calculation structures need to be first calculated. This is most of the time the reason for a short freeze at simulation start. But the second time you run the same simulation, that freeze should not occure anymore, since the calculation structures (e.g. used in collision detection, etc.) have already been computed.
In your case, the message says that you are trying to start a remote API server service on a wrong port. So you should correct for that error. Also, if you are able to establish connection with V-REP, you must be using another port.
Another question: if you run the simulation without your remote API client connected, do you also have that freeze or delay?
