Problem on vrep.py
Filipe Rocha
Problem on vrep.py
Post by Filipe Rocha » 16 Jan 2019, 15:12
Hello everyone.
I am programming an python code to interface with a V-REP scene.
Specs: VREP 3.5.0 (rev 6) on Ubuntu 16.04. Programming on Pycharm CE with Python 3.5 interpreter.
When invoking vrep.py withing my custom code, I get the following error:
BibVrepMethods invoked successfully
  File "/home/filipe/Documents/gitSources/arcaboucoTrabalhosAutonomosCOPPE/filtersPyCharm/src/CustomLibraries/BibVrepMethods/BibVrepMethods.py", line 29, in <module>
    test = BibVrepMethods()
  File "/home/filipe/Documents/gitSources/arcaboucoTrabalhosAutonomosCOPPE/filtersPyCharm/src/CustomLibraries/BibVrepMethods/BibVrepMethods.py", line 21, in __init__
    import vrep
  File "/home/filipe/Documents/gitSources/arcaboucoTrabalhosAutonomosCOPPE/filtersPyCharm/src/CustomLibraries/BibVrepMethods/vrep.py", line 67, in <module>
    c_GetObjectQuaternion       = ct.CFUNCTYPE(ct.c_int32,ct.c_int32, ct.c_int32, ct.c_int32, ct.POINTER(ct.c_float), ct.c_int32)(("simxGetObjectQuaternion", libsimx))
AttributeError: /home/filipe/Documents/gitSources/arcaboucoTrabalhosAutonomosCOPPE/filtersPyCharm/src/CustomLibraries/BibVrepMethods/remoteApi.so: undefined symbol: simxGetObjectQuaternion
Process finished with exit code 1
Simple commented this line 67, re-run the code and get:
    import vrep
  File "/home/filipe/Documents/gitSources/arcaboucoTrabalhosAutonomosCOPPE/filtersPyCharm/src/CustomLibraries/BibVrepMethods/vrep.py", line 70, in <module>
    c_SetObjectQuaternion       = ct.CFUNCTYPE(ct.c_int32,ct.c_int32, ct.c_int32, ct.c_int32, ct.POINTER(ct.c_float), ct.c_int32)(("simxSetObjectQuaternion", libsimx))
AttributeError: /home/filipe/Documents/gitSources/arcaboucoTrabalhosAutonomosCOPPE/filtersPyCharm/src/CustomLibraries/BibVrepMethods/remoteApi.so: undefined symbol: simxSetObjectQuaternion
Another time, simple commented line 70 and, finally, my custom code correctly imports vrep.py.
I ran simpleTest.py, with my modified version of vrep.py and it connects to my running V-REP instance.
Apparently, everything should work fine, except from the c_GetObjectQuaternion and c_SetObjectQuaternion methods.
In advance, thank you for the great job on the V-REP program.
Best regards.
Re: Problem on vrep.py
Post by coppelia » 18 Jan 2019, 10:05
you must be running an old version of the remote API library (i.e. remoteApi.so). THe one that comes with V-REP V3.5.0 rev.6 works fine.
