Shared Memory problem when using 'simxCallScriptFunction'
sjames
Post by sjames » 18 Jan 2019, 19:35
I believe I have found a bug, but if I have missed something, then I apologise in advanced.
The issue is when calling 'simxCallScriptFunction' from python when using shared memory, and the function itself does a lot of computation.
The bug can be reproduced by simply having a script function like so:
test=function(inInts,inFloats,inStrings,inBuffer)
    for i=1,99999,1 do
        print(i)
    return {1},{},{},''
and then calling this from Python using 'simxCallScriptFunction'. The function on the Python side will hang; specifically when calling 'c_CallScriptFunction(...)'.
I have made sure that my port number <0, and have set a high negative timeout (e.g. -50000).
Note, that when I use port communication, it works fine. Perhaps there is timeout happening with shared memory?
Also of note, when I set 'doNotReconnectOnceDisconnected=False' when connected via shared memory, I get the following after the loop in the script finishes:
Connect (0): Failed to open the shared memory "/LocalVREP_REMOTE_API00001"
Thanks!
Re: Shared Memory problem when using 'simxCallScriptFunction'
Post by coppelia » 25 Jan 2019, 11:48
Hello James,
indeed, there is something fishy...
Thanks for pointing this out.
Post by coppelia » 25 Jan 2019, 11:54
can you tell me which platform you are running on?
sjames
Post by sjames » 25 Jan 2019, 16:30
I am running on Linux (Ubuntu 18.04).
Anything I can help with?
Also, on a related note, is it possible to support multiple instances when using shared memory? I.e. is it possible to allocate a portion of the memory, so that another instance can have another portion?
Post by coppelia » 28 Jan 2019, 15:20
Thanks,
normally you can have several shared memory remote API clients by specifying each time a different, negative port number (i.e. similar to creating several clients when using socket communication).
