Using simxCallScriptFunction in headless mode
3mayuge3
Post by 3mayuge3 » 24 Jan 2019, 04:34
I have one question about headless mode. I would like to call my function written in child script when the simulation is headless mode. I using python code (remote API), so it's better to use simxCallScriptFunction. I tried that, but it didn't work well (get return code 8).
In the first place, is it possible to call functions via remote API in headless mode?
Thank you.
Re: Using simxCallScriptFunction in headless mode
Post by coppelia » 25 Jan 2019, 11:23
that should normally work. Return value 8 means simx_return_remote_error_flag, i.e. an error occured on the server side. Are you sure your scene is correctly loaded? Are you sure your simulation is running (you can't call a child script function if simulation is not running).
3mayuge3
Post by 3mayuge3 » 27 Jan 2019, 06:05
Thank you for your reply.
Ok, I' ll check simulation and scene again. Thank you for your advice.
