Save Greyscale Image from Vision Sensor
mirovoellmy
Post by mirovoellmy »
I'm trying to record a greyscale vision sensor and save some images to drive using sim.saveImage().
The documentation describes that the the function can only handle rgb and rgbd images. Did I miss something or do I have to manually convert my greyscale [res_x * res_y] image to a rgb [res_x * res_y * 3] image everytime I want to save an image?
If yes, it would be nice to have an option in the saveImage() function so it can also save grayscale images. :)
Miro
Re: Save Greyscale Image from Vision Sensor
you can use sim.transformBuffer for that:
rgbImage=sim.transformBuffer(greyImage,sim.buffer_uint8,1,0,sim.buffer_uint8rgb)
ales_v
Post by ales_v »
I would like to ask if there is an oportunity to save grayscale image (monocolor or 8bit depth).
My goal is to have a small file but in good quality.
Thank you
as of CoppeliaSim 4.0.0, this is unfortunately not possible. But in next release you'll be able to do that with, e.g.:
        local img,resX,resY=sim.getVisionSensorCharImage(visionSensorHandle)
        img=sim.transformBuffer(img,sim.buffer_uint8rgb,1,0,sim.buffer_uint8)
        sim.saveImage(img,{resX,resY},2,"testImg.png",100)
lynsdu
Post by lynsdu »
hi there,
I am currently using b0 remote API with C++ on visual studio, do you know how to save an image from the vision sensor?
int visionsensor = b0RemoteApi::readInt(client.simxGetObjectHandle("Vision_sensor", client.simxServiceCall()), 1);
std::vector<msgpack::object>* imginfo = client.simxGetVisionSensorImage(visionsensor, 0, client.simxServiceCall());
b0RemoteApi::print(imginfo);
I have been checking examples but with any clue how to use functions to save it as an image. could you please provide some examples for that?
thanks.
to save an image from CoppeliaSim is quite immediate with the sim.saveImage function. From an external application, you'll have to use your own or a third-library routines to handle that. Here if you use Qt.
ask4jubad
Post by ask4jubad »
Hello Coppelia,
When one uses sim.saveImage where does the image reside?
I can seem to find it - perhaps it's not working for me. I don't get any error, so I am not sure if the saveImage works or not.
From either the external script or within an actuation function in my simulator, I run this:
local img, resX, resY, sim.getVisionSensorCharImage(visionSensorHandle) -- in external python script, there is no keyword local though
sim.saveImage(img, {resX, resY}, 0, "test.png", 100) -- i've also tried [resX, resY] and I can't remember which combination returns an error.
as far as I know, this will place the file in the CoppeliaSim folder. Best is to specify an absolute path.
