VREP randomly cannot find remoteApiCommandServer.lua or any related .so libraries
agsdyson
Post by agsdyson » 08 Mar 2019, 08:55
I am launching VREP from python and am using a slightly modified version of the remoteApiCommandServer.ttt file
 args = [os.path.join(vrepPath, "vrep.sh"), "-gREMOTEAPISERVERSERVICE_" + str(portNum) + "_FALSE_FALSE", remoteAPIscene.ttt]
subprocess.Popen(args, shell=False, cwd=vrepPath)
I've been leaving a batch job to run overnight where it will spawn vrep, do some calculation, shut down vrep and spawn a new instance over and over. The spawning code works fine in general, but after at least an hour it randomly comes up with this error. Sometimes it can run for several hours before crashing.
    stack traceback:
	[C]: in function 'require'
	[string "CHILD SCRIPT remoteApiCommandServer"]:1: in main chunk
Lua runtime error: [string "CHILD SCRIPT remoteApiCommandServer"]:1: module 'lua.remoteApiCommandServer' not found:
	no field package.preload['lua.remoteApiCommandServer']
	no file './lua/remoteApiCommandServer.lua'
	no file '/usr/local/share/lua/5.1/lua/remoteApiCommandServer.lua'
	no file '/usr/local/share/lua/5.1/lua/remoteApiCommandServer/init.lua'
	no file '/usr/local/lib/lua/5.1/lua/remoteApiCommandServer.lua'
	no file '/usr/local/lib/lua/5.1/lua/remoteApiCommandServer/init.lua'
	no file '/home/ags/vrep/lua/remoteApiCommandServer.lua'
	no file '/home/ags/vrep/lua/lua/remoteApiCommandServer.lua'
	no file '/home/ags/vrep/BlueWorkforce/lua/remoteApiCommandServer.lua'
	no file '/home/ags/vrep/../../scenes/lua/remoteApiCommandServer.lua'
	no file './lua/remoteApiCommandServer.so'
	no file './liblua/remoteApiCommandServer51.so'
	no file '/usr/local/lib/lua/5.1/lua/remoteApiCommandServer.so'
	no file '/usr/local/lib/lua/5.1/liblua/remoteApiCommandServer51.so'
	no file '/usr/local/lib/lua/5.1/loadall.so'
	no file './lua.so'
	no file './liblua51.so'
	no file '/usr/local/lib/lua/5.1/lua.so'
	no file '/usr/local/lib/lua/5.1/liblua51.so'
Any ideas of what could be causing this?
agsdyson
Re: VREP randomly cannot find remoteApiCommandServer.lua or any related .so libraries
Post by agsdyson » 08 Mar 2019, 09:16
The return value of the vrep.simxGetLastErrors() is:
'Object does not exist. (simGetObjectHandle)'
Post by coppelia » 08 Mar 2019, 11:05
are you running the latest V-REP version? i.e. 3.6.0?
agsdyson
Post by agsdyson » 11 Mar 2019, 08:55
Yes, I am running 3.6.0. The getLastErrors() command results may not be related to the crash. I think the error occurs regardless of the crash or not.
Post by coppelia » 13 Mar 2019, 13:36
you mention a crash. The reported error messages come from the V-REP status bar, and are not (directly) linked to the crash (btw, what library or file do you include via the require directive?). What does the console print?
Also, can you prepare a minimalistic example that illustrates your crash, so that we can potentially reproduce it easily?
agsdyson
Post by agsdyson » 14 Mar 2019, 13:48
I include a set of lua functions that I have wrapped so they can be called from the external api.
I'm not sure what the console prints because have a desktop shortcut to launch vrep that does not open a console window. The status bar message is directly linked to the crash. The message says that the lua file with my custom functions cannot be loaded, and therefore my code crashes when I try to call those functions.
I am working on creating a minimal example, but it is taking a while because the crash is non deterministic and generally only happens after several hours.
agsdyson
Post by agsdyson » 19 Mar 2019, 09:52
I don't have a minimal example working yet, but I left a reduced sample running overnight and found that vrep has used up 250GB of ram.
https://imgur.com/a/p5le2lt
The top process is vrep, the one underneath is the python code where I continuously connect, create some objects, disconnect and repeat. When I stop simulation and disconnect the world should get reset and not increase in memory usage.
Is this assumption correct or are there resources that I need to free before stopping the simulation and disconnecting?
I will try to get a minimal example of this working.
agsdyson
Post by agsdyson » 19 Mar 2019, 12:08
This error comes up in my python program if I launch multiple versions of VREP on the same port and try to connect from multiple python processes.
ALSA lib pcm.c:7963:(snd_pcm_recover) underrun occurred
agsdyson
Post by agsdyson » 20 Mar 2019, 12:26
I have a minimum working example. Ubuntu 16.04 64 bit, V-REP 3.6.1 rev1
https://www.dropbox.com/s/r3yitxsum4sr0 ... e.zip?dl=0
extract the zip in the VREP folder containing vrep.sh. run minimumExample.sh. This will launch 8 VREP instances and 8 instances of minimalExample.py each with a unique port. The python code connects to the remoteApiCommandServer, spawns a dummy object and closes the connection in an infinite loop.
If running in headed mode, you will need to close the warning dialogues than appear after vrep first opens, if you comment out the headed mode and uncomment headless mode in minimumExample.py, you don't need to click any dialogues.
The code crashes because python fails to connect after around 1600 seconds on my machine. In my original non minimal example code, it would crash after 2400-2800 seconds.
The code does not break nicely with ctrl-c so use ./minimalExample/killAll.sh which will kill all open vrep and minimalExample.py processes.
I hope this is helpful.
Post by coppelia » 22 Mar 2019, 15:38
Thanks for that example. Quick question: is it still crashing if simply connecting /disconnecting (maybe with some waiting time in-between), or is the dummy creation and/or simulation start/stop relevant?
