V-REP crashes after selecting SDF import option from Plugins drop down menu
Smitty44
Post by Smitty44 »
Hi there,
I'm brand new to V-REP. I installed V-REP PRO EDU 3.6.0 for windows, about a month ago.
But before I used it, I received the notification that 3.6.1 was available.
So, I installed that one. I have created a robot model using Fusion 360 and used its addin to export it for V-REP.
After starting V-REP interface, I chose <plugin > from the menu and clicked on <SDF import...>.
After a few seconds, V-REP crashed.
The messages from the terminal indicates everything loaded successfully, including SDF.
Exactly when I clicked on SDF import..., the following message appeared in the terminal:
CustomUI: d:\v_rep\programming\v_repextcustomui\plugin.cpp:53 FATAL: fileDialog should NOT be called from UI thread
...then nothing for a few seconds, but as it crashed, this message showed for a split second:
So, my first thought is, its probably related to a version mismatch of some type.
I do have Python 3.6.5 (Anaconda3 5.2.0 64-bit distribution), Fusion 360, Java 8 Update 191 (64-bit), Visual Studio, and Visual C++ with dates: 2010 thru 2017, loaded on my Alienware Aurora purchased last September.
So, I uninstalled the V-REP 3.6.1 version and went back to 3.6.0. But same result.
I searched on the internet and on the forum but didn't find any matches.
Has anyone encountered this or know what the messages really point to?
Re: V-REP crashes after selecting SDF import option from Plugins drop down menu
thanks for reporting this issue.
A few questions:
  • Does it happen always (i.e. when trying multiple times)?
  • Does it happen with any SDF model?
  • Can you share a SDF model which causes the crash?
Smitty44
Post by Smitty44 »
Hi fferri,
Thanks for replying.
Yes it happens every time.
I never get the chance to attempt to import a model.
It crashes exactly when I choose <SDF import...> from the Plugins drop down list.
thanks for reporting this. The bug has been corrected in V-REP 3.6.1. rev2, available for download now.
Smitty44
Post by Smitty44 »
Heck YEAH!
Thank you for the quick response!!
I will try it before the week is out and report back.
