how to import mesh (one with obj, mtl and png files) using lua API
Re: how to import mesh (one with obj, mtl and png files) using lua API
Post by coppelia » 16 Apr 2019, 06:40
I tried both..
st2yang
Post by st2yang » 28 Apr 2019, 20:38
coppelia wrote:
15 Apr 2019, 14:55
hum... then there must be a bug somewhere...
In the mean time you can simply convert your file into a different format. The other format will hopefully not cause problems.
Hi coppelia,
I think obj is currently the only format that allows importing of textured meshes in V-REP, right? Can I convert obj into other formats whose texture would be supported? Thank you!
Best,
st2yang
Post by coppelia » 29 Apr 2019, 08:14
Collada also supports textures...
