Use of old-style cast
neshom
Post by neshom »
I am using V-REP C++ API in Qt. I call V-REP functions like this:
simxSetFloatingParameter(vrepClientID, sim_floatparam_simulation_time_step, (simxFloat)0.05, simx_opmode_blocking);
It works, but I get the following warning because of (simxFloat)0.05:
Semantic Issue:
warning: use of old-style cas
I can solve it by using the function like this:
simxSetFloatingParameter(vrepClientID, sim_floatparam_simulation_time_step, static_cast<float>(0.05), simx_opmode_blocking);
Is this correct? Is there any shorter version?
Re: Use of old-style cast
That is correct. In C++ there are only the xxx_cast<...>(...) operators.
