Issues on Recompute Path for Robot Path Planning
Jacky
Post by Jacky »
Hi, Dear fferi and coppelia:
Sorry for bothering sincerely, I met an issue, that is when I doing path planning, I giving different goal position to a dummy to let pioneer robot following. But, the first time, second times, third times, fourth times all making sense, I mean the robot can flowing the path successfully, but when the five times goal change, the robot doesn't following the path, it will just heading to the goal dummy straightly without following the path we generated from OMPL function.
In my understand, the problem may occur at the many data comes out, because I got a large map (200*300meters) for path planning. Also in the Scene hierarchy, the path becomes more and more on the list, I think we should do clean up function each time to help robot get the clearly data.
Here is my code, thanks! Looking forward help from your guys expert!
Yours Sincerely
Jack
        --Handle of the robot and target
        --startHandle=sim.getObjectHandle('StartConfiguration')
        goalHandle=sim.getObjectHandle('UGV_GOAL_1')
        robotHandle=sim.getObjectHandle('Pioneer_p3dx')
        --robotHandle=sim.getObjectHandle('UGV1_Basic')
        --motor handle
        rightMotor=sim.getObjectHandle('Pioneer_p3dx_rightMotor')
        leftMotor=sim.getObjectHandle('Pioneer_p3dx_leftMotor')
        --This is for recompute path
        desiredTargetPos={-99,-99}
        --Create a task object, used to represent the motion planning task
        t=simOMPL.createTask('t')
            --it return a task handle: t
        --Create a component of the state space for the motion planning problem
        --simOMPL.setStateValidityCheckingResolution(t,0.002)
        ss={simOMPL.createStateSpace('2d',simOMPL.StateSpaceType.pose2d,robotHandle,{-45,-150},{263,39},1)} --This is for full plant
        --ss={simOMPL.createStateSpace('2d',simOMPL.StateSpaceType.pose2d,robotHandle,{218,-66},{235,-50},1)}
                                     --[1]: a name for state space
                                     --[2]: set 2d mode
                                     --[3]: robot handle
                                     --[4]: low bounds
                                     --[5]: high bounds
                                     --[6]: Lua 1 was true
                                            --if 1 then
                                               --print('jack')
                                            --end
        --Set the state space of this task object
        simOMPL.setStateSpace(t,ss)
            --[1]: a handle name created from simOMPL.createTask
            --[2]: a table of handles to state space components created from simOMPL.createStateSpace
        --Set the search algorithm for the specified task
        simOMPL.setAlgorithm(t,simOMPL.Algorithm.TRRT)
            --[2]: selected algorithm
        --Set the obstacles can be detected
        simOMPL.setCollisionPairs(t,{robotHandle,sim.getCollectionHandle('Maze')})
            --[2]: a table containing 2 entity handles for each collision pair, e.g: {robot,obstacles}
        --Start pose get and set
        startpos=sim.getObjectPosition(robotHandle,-1)
        startorient=sim.getObjectOrientation(robotHandle,-1)
        startpose={startpos[1],startpos[2],startorient[3]}   --x,y,c
        simOMPL.setStartState(t,startpose)
        --Goal pose get and set
        goalpos=sim.getObjectPosition(goalHandle,-1)
        goalorient=sim.getObjectOrientation(goalHandle,-1)
        goalpose={goalpos[1],goalpos[2],goalorient[3]}
        simOMPL.setGoalState(t,goalpose)
        --Compute the path
        r,path=simOMPL.compute(t,4,-1,800)
            --[2]: maximum time used for the path searching procedure, in seconds
            --[3]: maximum time used for the path simplification procedure, in seconds. -1 for a default simplification procedure.
            --[4]: minimum number of states to be returned
            --return value: r is bool, true or false. True is path solution found
                          --path is a table, from start to goal. States are specified linearly
        --Creat path
        pathHandle=sim.createPath(-1, nil, nil, nil)
            --[1]: a combination of path properties, -1 for default attributes
            --[2]: input the line size{[1]}, the path length calculation method{[2]}, reserved{[3]}????
            --[3]: input the control point size{[1]}, the angular to linear conversion coefficient{[2]}, the virtual distance scaling factor{[3]}
            --[4]: the colors of the path
        --Inserts one or several control points into a path object
        pc=#path/3  --800 is pc, the total number of path point solution, #path is 2400 in this case
        for i=1,pc-1,1 do
            sim.insertPathCtrlPoints(pathHandle,0,i,1,{path[(i-1)*3+1],path[(i-1)*3+2],0,0,0,0,0,0,0,0,0})
            --[1]: the handle of the path
            --[2]: bit coded. 0 is for 11 bits, 1 is for 16 bits
            --[3]: the first new control point be inserted
            --[4]: the number of control points to insert each time
            --[5]: a buffer of [4]*[2], 11bits from O bit code setting.
                    --{[1]-[6]}: the position of the control point (x,y,z,a,b,c), relative to the path object
        --Get the path object lengths in meters
        path_length=sim.getPathLength(pathHandle)
            --[1]: handle of the path object
        nominalVelocity=150*math.pi/180
        rightV=0
        leftV=0
        currentPosOnPath=0
      --[[  --get the handle of distance objects
        L=0.381
        R=0.0975
        Kp=0.8
        --This is
        pos_on_path=0
        --Robot speed
        vn=0.2--]]
function sysCall_actuation()
        -- Read the distance between mona and different object
        --res,distancepionner=sim.readDistance(distpionner)
        --real_time=sim.getSimulationTime()
        --Read goal position data
        targetP=sim.getObjectPosition(goalHandle,-1)
        xtarget=targetP[1]
        ytarget=targetP[2]
        --This is for recompute the path when target moving
        xylength={targetP[1]-desiredTargetPos[1],targetP[2]-desiredTargetPos[2]} --[1]: x direction length of moving --[2]: y direction length of moving
        if (math.sqrt(xylength[1]*xylength[1]+xylength[2]*xylength[2])>0.01) then --if the target change position, the sqrt of (a^2+b^2) has to big than 0
                                            --No path now, need to recompute the path when it's 0
            desiredTargetPos[1]=targetP[1]  --To put currenlty target position data in to the desired target position for coving the data
            desiredTargetPos[2]=targetP[2]
                    --motor handle
                    --This is
                    --pos_on_path=0
                    t1=simOMPL.createTask('t1')
                    --simOMPL.setStateValidityCheckingResolution(t1,0.002)
                                                 --[2]: set 2d mode
                                                 --[3]: robot handle
                                                 --[4]: low bounds
                                                 --[5]: high bounds
                                                        --if 1 then
                                                           --print('jack')
                                                        --end
                    simOMPL.setStateSpace(t1,ss)
                    simOMPL.setAlgorithm(t1,simOMPL.Algorithm.TRRT)
                    simOMPL.setCollisionPairs(t1,{robotHandle,sim.getCollectionHandle('Maze')})
                    simOMPL.setStartState(t1,startpose)
                    simOMPL.setGoalState(t1,goalpose)
                    --Compute the path
                    r,path=simOMPL.compute(t1,20,-1,800)
                    --Creat path
                    for i=1,pc-1,1 do
        l=sim.getPathLength(pathHandle)
        r=sim.getObjectPosition(robotHandle,-1)
        --position=sim.getPositionOnPath(pathHandle,pos_on_path)
        p=sim.getPositionOnPath(pathHandle,currentPosOnPath/l)
            --[2]: a value between 0 and 1, where 0 is the beginning of the path, and 1 the end of the path
        d=math.sqrt((p[1]-r[1])*(p[1]-r[1])+(p[2]-r[2])*(p[2]-r[2]))
        currentPosOnPath=currentPosOnPath+0.01
        M=sim.getObjectMatrix(robotHandle,-1)   --world frame
            --print('world frame robot=',M)
        sim.invertMatrix(M)                     --invert the rotation matrix
            --print('invert results=',M)
        path_pos=sim.multiplyVector(M,p) --robot frame
            --print('robot frame=',path_pos)
        --distancia=math.sqrt((path_pos[1])^2+(path_pos[2])^2)
        angulo=math.atan2(path_pos[2],path_pos[1])
                if (angulo>=0)and(angulo<math.pi*0.5) then
                    rightV=nominalVelocity
                    leftV=nominalVelocity*(1-2*angulo/(math.pi*0.5))
                if (angulo>=math.pi*0.5) then
                    leftV=-nominalVelocity
                    rightV=nominalVelocity*(1-2*(angulo-math.pi*0.5)/(math.pi*0.5))
                if (angulo<0)and(angulo>-math.pi*0.5) then
                    rightV=nominalVelocity*(1+2*angulo/(math.pi*0.5))
                if (angulo<=-math.pi*0.5) then
                    rightV=-nominalVelocity
                    leftV=nominalVelocity*(1+2*(angulo+math.pi*0.5)/(math.pi*0.5))
        sim.setJointTargetVelocity(leftMotor,leftV)
        sim.setJointTargetVelocity(rightMotor,rightV)
    --Get the currently robot Position and Orientation on the Path
    --[[    position=sim.getPositionOnPath(pathHandle,pos_on_path)
        orientation=sim.getOrientationOnPath(pathHandle,pos_on_path)
        --if r then
            --print('r=',r)
            --print('#path=',#path)
            --print('path=',path)
            --print('path1x=',path[1],'path1y=',path[2],'path1c=',path[3])
            --print('path2x=',path[4],'path2y=',path[5],'path2c=',path[6])
            --print('pc=',pc)
            --print('path_length=',path_length)
            --print('pathHandle=',pathHandle)
            --print('position=',position)
            --print('orientation=',orientation)
        --end
        path_pos=sim.multiplyVector(M,position) --robot frame
        if (pos_on_path < 1) then
            v=vn
            o=Kp*angulo
        else -- Stop at the end of the path
            v=0
            o=0
        wr=(v+L*o)/R
        wl=(v-L*o)/R
        sim.setJointTargetVelocity(leftMotor,wl)
        sim.setJointTargetVelocity(rightMotor,wr)
        if (distancia < 1/path_length) then
            pos_on_path=pos_on_path+v*sim.getSimulationTimeStep()
        end--]]
function sysCall_sensing()
    -- put your sensing code here
function sysCall_cleanup()
Re: Issues on Recompute Path for Robot Path Planning
Why the call to simOMPL.setStateValidityCheckingResolution is commented out?
Jacky
Post by Jacky »
Hi,Dear fferri:
Thanks for your reply sincerely, I am bring it(simOMPL.setStateValidityCheckingResolution) back already, but is still not working!
I find the problem is not only in the fivth times, even first time we giving the obstacle between robot and goal dummy, after 60 seconds, the path generated on the ground floor, but robot still not following the path, the robot just heading to the right direction to the goal dummy!
I doubt, the path is not generated successfully, even we can see it, this is because when we doing path planning calculation, if we stop the simulation suddenly, a right path will show up. Path planning in large scale places issues, if you can, please help, dear fferri.
Yours Sincerely
Jack
Please make a minimal testcase that reproduces the problem
Jacky
Post by Jacky »
Thanks a lot! Have a nice day!
