How to configure Qt program to communicate with v-rep via b0 remote api?
wangsc
Post by wangsc » 10 Jul 2019, 10:20
I am using b0 remote api to connect Qt with v-rep, I have put the Qt program to the same path of the official bubbleRobClinet program, i.e. programming/b0RemoteApiBindings/cpp, and configured the .pro file almost the same as bubbleRobClient.pro.
However, there are still some dependency problems in my program. Firstly, I have included the path to programming/blueZero/include/b0/bindings with the following code the same as official bubbleRobClient.pro:
INCLUDEPATH += $$B0_INCLUDEPATH/b0/bindings
and I got an error from b0RemoteApi.h:
'c.h' file not found
Then I used relative path:
INCLUDEPATH += ../../../bluezero/include/b0/bindings
and I got another error:
error: LNK1146: no argument specified with option '/LIBPATH:'
The absolute path didn't work either.
How can I configure my Qt program properly? Any help would be appreciated.
Re: How to configure Qt program to communicate with v-rep via b0 remote api?
Post by coppelia » 15 Jul 2019, 06:33
you must do something wrong in the way you are specifying the includepath. Which platform are you on?
wangsc
Post by wangsc » 16 Jul 2019, 02:29
coppelia wrote:
15 Jul 2019, 06:33
Thank you for your reply.
I'm using v-rep pro edu v3.6.1 and Qt Creator on Windows 10, and this is how I include the required paths:
INCLUDEPATH += E:\boost_1_68_0
INCLUDEPATH += ..
INCLUDEPATH += ../msgpack-c/include
BTW, I also have problem to link the bluezero library, because I find b0.dll in the root directory of vrep and b0.h in programming/bluezero/include/b0/.
