How to save a model of my robot?
Ulrich
Post by Ulrich »
How can I extract a model of my scene and save it as a model, so that I can use it via simple drag-and-drop?
Re: How to save a model of my robot?
First, your model needs to be tagged as such. Refer to this section in the user manual.
Once the model base object is correctly tagged, select it (i.e. just one object should be selected), then click [Menu bar --> File --> Save model as...]. Select the following folder as destination (somewhere in there): V-REP installation folder/models
Eric
Post by Eric »
Hi
Just select your model base, then file->save model as... , check the options you need in the following windows, get a nice icon for your model and save it in V-REP3/[v-rep folder]/models/robots/mobile or other category
It is advisable to also save it in a folder outside V-REP3 folder because when you update, everything under this folder will be deleted.
cheers,
Eric
ooops, thanks Eric, I was a tiny bit quicker :P
