How to achieve this bending motion for a changeable curvature mechanism?
biscuit122
Post by biscuit122 »
https://drive.google.com/file/d/1lYcM_R ... sp=sharing
Do you guys know how to achieve this bending motion for a changeable curvature mechanism in the mentioned video?
Re: How to achieve this bending motion for a changeable curvature mechanism?
if this needs to be kinematically simulated, then you could simply use revolute joints in passive mode mounted as:
base --> joint1 --> joint2 --> shape1 --> joint3 --> joint4 --> shape2 --> etc.
if this needs to be dynamically dimulated, then use revolute joints in force/torque mode mounted as:
base --> joint1 --> auxShape1 --> joint2 --> shape1 --> joint3 --> auxShape2 --> joint4 --> shape2 --> etc.
Consecutive joints should be mountd perpendicular to each other.
