Shortcuts
geerten
Re: Shortcuts
Post by geerten »
Well, indeed that's causing the not going 'round'. But that's strange, because the translation window does not take the focus..
minisch
Re: Shortcuts
Post by minisch »
It would be helpful to have a shortcut for the 'Fit-To-View' command. I really need it :)
Is it possible to add it?
Thanks.
Re: Shortcuts
this is something you could also implement with a customization script and the function simCameraFitToView.
But it is probably a good idea to add it hard-coded. What key combination would you suggest, or better, what do other applications use for that operation normally?
minisch
Re: Shortcuts
Post by minisch »
Thanks for the quick reply. I am using VREP coupled with SIMULINK and in the latter the SPACE-BAR is used to fit the view of the model to the screen. For this reason I would suggest the same shortcut.
Let me know what you think.
Re: Shortcuts
ctrl-space is already used to start/stop a simulation in V-REP.
So I used ctrl-b, which is still easily doable with the left hand ;)
minisch
Re: Shortcuts
Post by minisch »
I knew that but I meant just SPACE which doesn't look to me to be used for anything else.
By the way, when you say that YOU HAVE DONE IT, it means that it will be available in the next version released right?
Thanks.
Re: Shortcuts
Space alone doesn't work, it needs to be forwarded to the various key function, including simGetSimulatorMessage (e.g. when a scrips wants to check keyboard input).
The change will be available in next release, out hopefully until the end of the month.
minisch
Re: Shortcuts
Post by minisch »
Ok, thanks a lot for the support.
minisch
Re: Shortcuts
Post by minisch »
I checked the new version of VREP (3.2.0) but the feature seems not implemented.
I am doing something wrong or it will be implemented in the next releases?
Thanks.
Re: Shortcuts
Did you try <ctrl>-b ?
