Page 1 of 2
How to use the haptic device(TOUCH) to control the KUKA LBR_iiwa_7_R800 ?
Posted: 09 Jul 2021, 09:52
by zhangm365
Now, I am trying to use the Haptic Device(TOUCH 3D) to control the KUKA robot, Would you please guide me?What is the route of this task?
Bests,
zhangm365
Re: How to use the haptic device(TOUCH) to control the KUKA LBR_iiwa_7_R800 ?
Posted: 09 Jul 2021, 10:13
please check first if that device is supported by or compatible with
CHAI3D. If yes,
here is the CHAI3D plugin for CoppeliaSim. You'll have to compile it yourself, or we can also provide the binary for Windows.
Posted: 09 Jul 2021, 12:10
by zhangm365
The chai3d plugin can be successfully loaded! Then, I want to use the Haptic device(TOUCH 3D) to control the KUKA robot.
Thanks your reply!
Posted: 10 Jul 2021, 09:42
by zhangm365
Then, how to use the haptic device(TOUCH) to control the KUKA LBR_iiwa_7_R800 ?
How to continue this task?
Posted: 12 Jul 2021, 08:15
next, drag and drop the model Models/other/Interface to haptic device.ttm into the scene and run the simulation: you should see several shapes, that will move or rotate, and a small sphere that is linked to your haptic device. You can then move that sphere via your haptic device and interact (or at least feel) those created shapes in the scene. Have a look at the code of that model to get an idea how to have your device interact with some content in the scene.
Have also a look at the demo scene Scenes/hapticRobot.ttt
Posted: 24 Aug 2022, 11:21
by satheeshkumar_v
I am new to coppeliasim and visual basic. I have no idea how to compile the plugin in Visual basic. Would you please provide me the .dll file for 3d systems touch haptic device with coppelia sim.
Or would you please guide me with the step-by step tutorial please
Satheesh
Posted: 25 Aug 2022, 09:48
the
CHAI3D plugin for CoppeliaSim is a c++ project. You can download the Windows dll
here. Keep in mind that it was compiled for the newest release, and you might find some error messages. Let me know what it prints in the console.
Posted: 25 Aug 2022, 10:38
by satheeshkumar_v
Many thanks for your response. The following are the steps what I did and the console throws an error.
1. I have pasted the .dll in the installation directory
(C:\Program Files\CoppeliaRobotics\CoppeliaSimEdu).
2. And I started CoppeliaSim and dragged
"Interface to haptic device.ttm" from
models/others.
3. Then ran the simulation and the console throws "
[/hapticDevice@childScript:error] CHAI3D plugin was not found, or was not correctly initialized (simExtCHAI3D.dll)."
The console shows
Could not find function simMultiplyPoses
simExtCHAI3D: error: could not find all required functions in the CoppeliaSim library. Cannot start the plugin.
plugin 'CHAI3D': load failed (failed initialization)
Best
Satheesh
Posted: 26 Aug 2022, 15:45
Ok, that's what I would have expected, since it is linked against the development version of CoppeliaSim. One solution would be to set the environment variable COPPELIASIMPLUGIN_IGNORE_MISSING_SYMBOLS and try again.
Posted: 27 Aug 2022, 01:19
by satheeshkumar_v
Many thanks, I'll try that and let you know the outcome.
