How to use the haptic device(TOUCH) to control the KUKA LBR_iiwa_7_R800 ?
Re: How to use the haptic device(TOUCH) to control the KUKA LBR_iiwa_7_R800 ?
Now the plugin is successfully loaded but the console still shows error in childscript
[sandboxScript:info] Simulation started.
[/hapticDevice@childScript:error] 24: in simCHAI3D.start@simExtCHAI3D: Initialization failed.
stack traceback:
[C]: in function 'simExtCHAI3D_start'
[string "/hapticDevice@childScript"]:24: in function 'sysCall_init'
[sandboxScript:info] Simulation suspended.
Satheesh
stack traceback:
Satheesh
You do not have additional infos from the console? What does the terminal say?
Keep in mind that you will need an appropriate haptic device installed with its own software and drivers...
Hi
No additional info in the console. simulation gets suspended right after the error.
Also, No errors in the terminal, It says
[CoppeliaSim:loadinfo] plugin 'CHAI3D': loading...
[CoppeliaSim:loadinfo] plugin 'CHAI3D': load succeeded.
I have my touch haptic device connected and the respective software and drivers are installed. I could able to run few demos from the touch drivers and applications. The initialization fails within the coppelia only.
Installed Software:
thanks
Installed Software:
thanks
Your plugin is failing with the call:
That's a call to the CHAI3D function getDevice. If the device index is correct (did you try 0, 1, 2 or 3?), then it could mean that you have to compile the plugin yourself, using an updated version of CHAI3D.
// get access to the first available haptic device found
if (!DeviceHandler->getDevice(device, deviceIndex))
// your plugin fails getting the device and ends up in here
SceneLock->release();
return false;
Many thanks for letting me know.
I tried with all the device indices, Still not working.
I have never done the compilation of plugins, would you please tell me or share a link on how to do the same?
Satheesh
Satheesh
Compiling the plugin can be done with Qt Creator. Simply open the .pro file, edit it for adjusting for libraries paths, and compile.
Hi,coppelia wrote: ↑25 Aug 2022, 09:48 Hello,
the CHAI3D plugin for CoppeliaSim is a c++ project. You can download the Windows dll here. Keep in mind that it was compiled for the newest release, and you might find some error messages. Let me know what it prints in the console.
I am also new to coppeliasim and visual basic. I have no idea how to compile the plugin in Visual basic or QT(I just open the simChai3d.pro and debug, but errors occurred). The link is unavailable now, would you please provide me the .dll files compiled for windows system?
Thanks a lot!
Many thanks for your response. I ran the simulation and the console said CHAI3D plugin was not found, or was not correctly initialized (simExtCHAI3D.dll)." Since the file I downloaded was simChai3d.dll from the link, did I need the file simExtCHAI3D.dll? If so, could you provide this file? Thanks a lot!
Best wishes.
Best wishes.
You need to run CoppeliaSim V4.6, at least. Then you need to load the plugin from within your script, e.g.:
The console should tell you whether the plugins was successfully loaded. Of course in order to be successfully loaded, you need to make sure you have installed all the dependencies (for CHAI3D and your device), otherwise load will fail.
--lua
sim = require'sim'
simCHAI3D = require'simCHAI3D'
device = 0
toolRadius = 0.01
workspaceRadius = 0.2
simCHAI3D.start(device, toolRadius, workspaceRadius)
