New update? Missing lot of functionalities
r_dhak
Post by r_dhak »
Today when I launched CoppeliaSim, I noticed a lot of changes.
Example:
1) Path is a dummy object now and can be edited directly within the scene window (no need to go to edit path toolbar)
2) Joint IK mode is completely gone.
I would like to follow a path, earlier it was possible through (putting joints in hybrid IK mode)--
--Function Initialization:
threadFunction=function()
while true do
sim.followPath(target, path, 1, posOnPath, v, 0)
--Initialization of parameters:
path=sim.getObjectHandle('Path')
target=sim.getObjectHandle('Target')
pathLength=sim.getPathLength(path)
posOnPath=0 -- varies between 0 (start) and pathLength (end)
v=0.3 -- velocity of the movement on the path (0.025m/s)
res,err=xpcall(threadFunction,function(err) return debug.traceback(err) end)
if not res then
	sim.addStatusbarMessage('Lua runtime error: '..err)
Now I am getting an error
[C]: in function 'simGetPathLength'
[string "Target@childScript"]:11: in function 'sim_code_function_to_run'
Not sure how I can accomplish that now
Any help is appreciated.
Thank You.
r_dhak
Re: New update? Missing lot of functionalities
Post by r_dhak »
Never mind.
Got it. Need to define the IK in a script now.
yes, correct. You will see that defining functionality within a script (and not via the GUI) makes everything easier and faster in the long run. And also much more scalable. But if you really need, you can still temporarily enable old dialog items by setting showOldDlgs = true in system/usrset.txt.
dav_paul
Post by dav_paul »
Hi all, I would also like to add that I could not find the button to turn on/off to start an object's dynamics in sleep mode (in the dynamics dialog) until I used the flag showOldDlgs = true. Thank you for the solution!
in CoppeliaSim V4.3.rev4+, you'll be able to do, e.g.:
    h=sim.getObject('.')
    sim.setObjectInt32Param(h,sim.shapeintparam_sleepmodestart,1)
