Torque Control
amirmmi
Torque Control
Post by amirmmi »
It would be good to add a function that applies the desired amount of torque directly to a joint, even negative or positive torque.
Re: Torque Control
from CoppeliaSim V4.3.0.rev4 on, you will be able to use sim.setJointTargetForce, which accepts a signed value
amirmmi
Re: Torque Control
Post by amirmmi »
When will V4.3.0.rev4 be released?
Re: Torque Control
Not sure...
But you can use the following function as a workaround in the mean time:
function sim.setJointTargetForce(jointHandle,forceOrTorque)
    local v=sim.getJointTargetVelocity()
    if v*forceOrTorque<0 then
        sim.setJointTargetVelocity(-v)
    sim.setJointMaxForce(jointHandle,math.abs(forceOrTorque))
