CoppeliaSim 4.3.0 crashes on MacOS
Re: CoppeliaSim 4.3.0 crashes on MacOS
I've never observed anything like that on macOS.
Does it happen also with CoppeliaSim 4.3.0rev10 or 4.3.0rev4?
peter corke
Post by peter corke »
Thanks, I have rev10 working. The first time I right-click opened and got the message about it damaging my computer, only option is don't run or bin the app. I did it a second time and then had the option to open the app, and now it is working.
In my class I have students running BigSur, Catalina and Monterey. We have a workaround for 4.3.0 with Monterey, but some students have had crashes after the app is actually running. I'll share this tip with the class and see what the feedback is.
I do understand that it is Apple who is making all our lives difficult. I am happy that I can at least run it.
Yup, Apple likes to play hide-and-seek with those security options.
Also keep an eye if the app bundle gets labeled as malware (it happened to me when manually removing code signature directory from the app bundle) as in that case you don't have the option to open the app until you override malware protection for the app (right-click -> get info -> override malware protection).
CoppeliaSim 4.3.0 rev12 might have mistakenly labeled as for macOS 10.15, but instead it requires macOS 12... sorry about that.
CoppeliaSim 4.3.0 rev10 should work fine on macOS 10.15, as you found out. However, macOS 10.15 is becoming obsolete (end-of-life planned for next year) and newer CoppeliaSim releases will require macOS 12.
peter corke
Thanks for the extra info. Will need to ensure that students are all uptodate with their OS, we have some going back to Big Sur.
peeraCPsim
Post by peeraCPsim »
My macOS version 12.2.1. I've done the above suggestions but not working.
peeraCPsim
peeraCPsim wrote: 01 Sep 2022, 14:29 My macOS version 12.2.1. I've done the above suggestions but not working.
I've got it worked now by installing 4.3rev10 instead.
LuisRicardo
Post by LuisRicardo »
fferri wrote: 17 Aug 2022, 07:48 I've never observed anything like that on macOS.
This works!! In the third try to open, finally the Coppeliasim Rev10 worked in my Mac 10.15.7
