OMPL reports solved paths that are incorrect
JBaxter
Post by JBaxter »
Hello!
I am trying to use V-REP's OMPL to motion plan for a robot. I am finding that simOMPL.solve() returns true despite the "solution" returned by simOMPL.getPath() not reaching the goal state. I don't know what is going wrong, as far as I can tell everything I am doing is correct.
I have an example scene file here:
https://drive.google.com/file/d/1nr9Q3_ ... sp=sharing
I am using OSX and the EDU version of V-REP 3.5.0 rev 4.
Thank you very much for your time!
Re: OMPL reports solved paths that are incorrect
I'm not sure wether OMPL would return the last state corresponding to goal.
Can you double-check that the last state in the path returned by OMPL cannot be connected (i.e. by linear interpolation) to the goal state? (you may want to add some obstacles to your example to have a realistic testcase)
JBaxter
Post by JBaxter »
Not returning a path to the goal would be very surprising behavior, if that is the case it should be documented.
Edit: I tried adding an obstacle preventing straightline solutions and the strange behavior persists, specifically the last state in the path is clearly not connectable to the specified goal (I put a table in the way).
nex
Post by nex »
Any news on this issue?
