vrep folder missing
vra
vrep folder missing
Post by vra »
Hi all, how are you?. First I whish to congratulate the team of coppelia for such an excellent program to simulate robots and their behaviors.
Now I need to ask for something, I've downloaded the Coppelia versions for windows and ubunti 64 bits, the windows version works flawleslly but the ubuntu version which I'm trying to install in debian 9 apparently doesn't have the folder vrep after uncompressed from the .tar.xz file and therefore I can't install it, what can I do about it?.
Thanks in advance for the help.
Re: vrep folder missing
it doesn't have any vrep folder anymore, since the software changed to CoppeliaSim. On Ubuntu there is no installation procedure. Simply decompress it, and from the terminal, in that folder, run coppeliaSim.sh
vra
Post by vra »
Hi, I taught that and tried to run that file before asking, then I had the following responses:
running it as a normal user:
root@d-valer:/media/valery/Users/valery/Downloads/CoppeliaSim_Edu_V4_0_0_Ubuntu18_04# sh coppeliaSim.sh
coppeliaSim.sh: 15: coppeliaSim.sh: Syntax error: "(" unexpected
running it as a superuser:
root@d-valer:/media/valery/Users/valery/Downloads/CoppeliaSim_Edu_V4_0_0_Ubuntu18_04# ./coppeliaSim.sh
Loading the CoppeliaSim library...
CoppeliaSim client app error: could not find or correctly load the CoppeliaSim library
and I couldn't run it.
Does it has a special requirement and do I need to place it in an specific folder?.
You are running it as superuser in both cases. the only difference is that in the first case you use the sh shell (wrong).
Simply run ./coppeliaSim.sh as normal user.
vra
Post by vra »
Thanks, I'll try
vra
Post by vra »
I've tried what you said as normal user and it keeps me saying that it couldn't find the coppelia libraries, look at the code below:
/media/valery/Users/valery/Downloads/CoppeliaSim_Edu_V4_0_0_Ubuntu18_04$ ./coppeliaSim.sh
in fact, it says the same as normal user and as superuser.
What can I do?
vra wrote:
19 Dec 2019, 22:32
You should check that:
  • libcoppeliaSim.so file is present and readable (maybe post the output of ls -l run in the CoppeliaSim_Edu_V4_0_0_Ubuntu18_0 directory)
  • all the dependencies are present (i.e. none is reported as not found). you can check that with ldd libcoppeliaSim.so
vra
Post by vra »
Well, libcoppeliaSim.so is present but my OS, debian 9 lacks GLIBC 2.27 and Qt5.12, I'm trying to learn how to install them, see the following answer from terminal.
./libcoppeliaSim.so: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.27' not found (required by ./libcoppeliaSim.so)
./libcoppeliaSim.so: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.12' not found (required by ./libcoppeliaSim.so)
	linux-vdso.so.1 (0x00007ffda5d3d000)
	liblua5.1.so => /usr/lib/x86_64-linux-gnu/liblua5.1.so (0x00007f4669622000)
	libQt5OpenGL.so.5 => /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5 (0x00007f466a9cd000)
	libQt5Widgets.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5 (0x00007f4668fbf000)
	libQt5Gui.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f4668a86000)
	libQt5SerialPort.so.5 => /usr/lib/x86_64-linux-gnu/libQt5SerialPort.so.5 (0x00007f466a9b4000)
	libQt5Core.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f46685b6000)
	libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007f4668344000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f4668127000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f4667da5000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4667aa1000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f466788a000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f46674eb000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f46672e7000)
	libharfbuzz.so.0 => /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f4667052000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f4666e38000)
	libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f4666c05000)
	libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x00007f466a98f000)
	libicui18n.so.57 => /usr/lib/x86_64-linux-gnu/libicui18n.so.57 (0x00007f466678a000)
	libicuuc.so.57 => /usr/lib/x86_64-linux-gnu/libicuuc.so.57 (0x00007f46663e2000)
	libpcre16.so.3 => /usr/lib/x86_64-linux-gnu/libpcre16.so.3 (0x00007f4666179000)
	libdouble-conversion.so.1 => /usr/lib/x86_64-linux-gnu/libdouble-conversion.so.1 (0x00007f4665f68000)
	libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f4665c54000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f4665a4c000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f466a82d000)
	libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f4665822000)
	libxcb-dri3.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0 (0x00007f466561f000)
	libxcb-present.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-present.so.0 (0x00007f466541c000)
	libxcb-sync.so.1 => /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007f4665215000)
	libxshmfence.so.1 => /usr/lib/x86_64-linux-gnu/libxshmfence.so.1 (0x00007f4665013000)
	libglapi.so.0 => /usr/lib/x86_64-linux-gnu/libglapi.so.0 (0x00007f4664de4000)
	libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f4664bd2000)
	libXdamage.so.1 => /usr/lib/x86_64-linux-gnu/libXdamage.so.1 (0x00007f46649cf000)
	libXfixes.so.3 => /usr/lib/x86_64-linux-gnu/libXfixes.so.3 (0x00007f46647c9000)
	libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007f46645c7000)
	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f4664287000)
	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f466405f000)
	libxcb-glx.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0 (0x00007f4663e44000)
	libxcb-dri2.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0 (0x00007f4663c3f000)
	libXxf86vm.so.1 => /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007f4663a39000)
	libdrm.so.2 => /usr/lib/x86_64-linux-gnu/libdrm.so.2 (0x00007f4663829000)
	libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f466357a000)
	libgraphite2.so.3 => /usr/lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f466334d000)
	libicudata.so.57 => /usr/lib/x86_64-linux-gnu/libicudata.so.57 (0x00007f46618d0000)
	libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f466165d000)
	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f4661459000)
	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f4661253000)
Anyway, if you can explain me how and where to get it i'll be grateful.
Ubuntu is the only supported Linux distribution.
Try rebuilding the library yourself. See compiling CoppeliaSim and related items.
vra
Post by vra »
Hi, I did a search around there and apparently the qt and GLIBC available for Debian 9 are inferior to the ones needed by coppelia and may be it's possible to install the needed ones by adding some repos but I managed to use coppeliaSim in a fastest way.
What I did was to install the windows version with playonlinux and using wine 64 bits, now it runs without problems until now.
