Running CoppeliaSim crashes with Error: signal 11
jens-troels
Post by jens-troels »
I cannot run CoppeliaSim Edu 4.0.0 on Linux Ubuntu 18.04. Whenever I try to run the ./coppeliaSim.sh through the terminal I get the following error 11:
Loading the CoppeliaSim library...
Done!
Launching CoppeliaSim...
lib: 1
lic: 1
CoppeliaSim Edu V4.0.0. (rev. 1)
Add-on script 'simAddOnScript-addOnScriptDemo.lua' was loaded.
Add-on script 'simAddOnScript-b0RemoteApiServer.lua' was loaded.
Add-on script 'simAddOnScript_PyRep.lua' was loaded.
If CoppeliaSim crashes now, try to install libgl1-mesa-dev on your system:
Error: signal 11:
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_Z11_segHandleri+0x2b)[0x7f76776a7eab]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f767b5f9f20]
/lib/x86_64-linux-gnu/libc.so.6(+0x18e5a1)[0x7f767b7495a1]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_Z15initGl_ifNeededv+0x110)[0x7f767788a330]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_ZN11CMainWindowC2Ev+0x7c0)[0x7f7677b869c0]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_ZN3App16createMainWindowEv+0x44)[0x7f767787a4b4]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_Z24simRunSimulator_internalPKciPFvvES2_S2_iS0_b+0x2f6)[0x7f76776b6206]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(simRunSimulatorEx+0xf)[0x7f76776a589f]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/coppeliaSim(+0x1a86)[0x55f115c0da86]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/coppeliaSim(+0x136e)[0x55f115c0d36e]
It seemed to happen after I updated my system, and I can't find any similar bugs or errors. I have been running V-REP without any issues and recently also CoppeliaSim without any errors as well.
Hope you can help and thank you in advance.
Re: Running CoppeliaSim crashes with Error: signal 11
did you try following?
jens-troels
coppelia wrote:
04 Mar 2020, 06:20
Yes, it did nothing for me. However, I noticed in looking in other threads that it was crashing when it was evaluating the graphics driver. Apparently, some of Nvidias drivers are buggy for ubuntu and specific graphic cards, so I decided to purge all the graphic drivers and revert to an older more stable version and it worked for.
You can consider it solved, and thanks!
Great, thanks for the feed-back!
