Running CoppeliaSim crashes with Error: signal 11
Posted: 03 Mar 2020, 16:00
I cannot run CoppeliaSim Edu 4.0.0 on Linux Ubuntu 18.04. Whenever I try to run the ./coppeliaSim.sh through the terminal I get the following error 11:
It seemed to happen after I updated my system, and I can't find any similar bugs or errors. I have been running V-REP without any issues and recently also CoppeliaSim without any errors as well.
Hope you can help and thank you in advance.
Loading the CoppeliaSim library...
Done!
Launching CoppeliaSim...
lib: 1
lic: 1
CoppeliaSim Edu V4.0.0. (rev. 1)
Add-on script 'simAddOnScript-addOnScriptDemo.lua' was loaded.
Add-on script 'simAddOnScript-b0RemoteApiServer.lua' was loaded.
Add-on script 'simAddOnScript_PyRep.lua' was loaded.
If CoppeliaSim crashes now, try to install libgl1-mesa-dev on your system:
Error: signal 11:
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_Z11_segHandleri+0x2b)[0x7f76776a7eab]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f767b5f9f20]
/lib/x86_64-linux-gnu/libc.so.6(+0x18e5a1)[0x7f767b7495a1]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_Z15initGl_ifNeededv+0x110)[0x7f767788a330]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_ZN11CMainWindowC2Ev+0x7c0)[0x7f7677b869c0]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_ZN3App16createMainWindowEv+0x44)[0x7f767787a4b4]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(_Z24simRunSimulator_internalPKciPFvvES2_S2_iS0_b+0x2f6)[0x7f76776b6206]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/libcoppeliaSim.so(simRunSimulatorEx+0xf)[0x7f76776a589f]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/coppeliaSim(+0x1a86)[0x55f115c0da86]
/home/jeh/9_semester/Master_Mathias/gorobots/projects/C-CPGRBFN/CPGRBFN_compact_v2/V-REP/VREP1/coppeliaSim(+0x136e)[0x55f115c0d36e]
