VS Code extension?
Posted: 31 Jul 2020, 18:47
for scripts is there a VS Code extension with intellisense? Please provide the link. Thanks
Questions/Answers around CoppeliaSim/V-REP
http://forum.coppeliarobotics.com/
function sysCall_init()
local st=-1
if sim.getInt32Parameter(sim.intparam_program_full_version)<4010002 then
st=0
local f=sim.getApiFunc(st,'+')
local v=sim.getApiFunc(st,'-')
local t={}
local b={}
for i=1,#f,1 do
b[f[i]]=true
t[#t+1]=f[i]
for i=1,#v,1 do
b[v[i]]=false
t[#t+1]=v[i]
table.sort(t)
finalTxt=header1
for i=1,#t,1 do
if b[t[i]] then
-- function
local s=sim.getApiInfo(st,t[i])
if s and not string.find(string.lower(s),"deprecated") then
s=string.gsub(s,"\n","")
local ep=string.find(s,")")
if ep then
s=string.sub(s,1,ep-1)
ep=string.find(s,"%(")
if ep then
local args=string.sub(s,ep+1)
ep=string.find(s,"=")
local rets=""
if ep then
rets=string.sub(s,0,ep-1)
finalTxt=finalTxt..[[ <KeyWord name="]]..t[i]..[[" func="yes">
if #rets>0 then
rets=rets.." ="
finalTxt=finalTxt..[[ <Overload retVal="]]..rets..[[" >
ep=string.find(args,",")
while ep do
s=string.sub(args,0,ep-1)
finalTxt=finalTxt..[[ <Param name="]]..s..[[" />
args=string.sub(args,ep+1)
finalTxt=finalTxt..[[ <Param name="]]..args..[[" />
finalTxt=finalTxt..[[ </Overload>
finalTxt=finalTxt..[[ </KeyWord>
-- constant
finalTxt=finalTxt..[[ <KeyWord name="]]..t[i]..[[" func="no"/>
finalTxt=finalTxt..footer1
local file=io.open("lua.xml","w")
file:write(finalTxt)
io.close(file)
sim.addLog(sim.verbosity_msgs,"Wrote 'lua.xml'")
finalTxt=header2
for i=1,#lkwds,1 do
t[#t+1]=lkwds[i]
table.sort(t)
for i=1,#t,1 do
if i>1 then
finalTxt=finalTxt.." "
finalTxt=finalTxt..t[i]
finalTxt=finalTxt..footer2
local file=io.open("langs.xml","w")
io.close(file)
sim.addLog(sim.verbosity_msgs,"Wrote 'langs.xml'")
header1=[[<?xml version="1.0" encoding="Windows-1252" ?>
<NotepadPlus>
<!-- language doesnt really mean anything, its more of a comment -->
<AutoComplete language="lua">
Environment specifies how the language should be interpreted. ignoreCase makes autocomplete
ignore any casing, start and stopFunc specify what chars a function starts and stops with.
param specifies parameter separator and terminal can be used to specify a character that stops
any function. Using the same character for different functions results in undefined behaviour.
05/11/2009
The basic word character are : A-Z a-z 0-9 and '_'
If your function name contains other characters,
add your characters in "additionalWordChar" attribute (without separator)
in order to make calltip hint work
<Environment ignoreCase="false" startFunc="(" stopFunc=")" paramSeparator="," terminal="" additionalWordChar="._"/>
The following items should be alphabetically ordered.
func="yes" means the keyword should be treated as a fuction, and thus can be used in the parameter
calltip system. If this is the case, the retVal attribute specifies the return value/type. Any
following Param tag specifies a parameter, they must be in order. The name attributes specifies
the parameter name.
footer1=[[ </AutoComplete>
</NotepadPlus>]]
header2=[[<?xml version="1.0" encoding="Windows-1252" ?>
<NotepadPlus>
<!-- The key words of the supported languages, don't touch them! -->
<Languages>
... etc]]
footer2=[[</Keywords>
</Language>
... etc
</Languages>
</NotepadPlus>]]
lkwds={"table.concat",
"table.insert",
"table.maxn",
"table.pack",
"table.remove",
"table.sort",
"table.unpack",
"tan",
"tanh",
"upper",
"sin",
"sinh",
"sqrt",
"string.byte",
"string.char",
"string.dump",
"string.find",
"string.format",
"string.gmatch",
"string.gsub",
"string.len",
"string.lower",
"string.match",
"string.rep",
"string.reverse",
"string.sub",
"string.upper",
"sub",
"abs",
"acos",
"arshift",
"asin",
"atan",
"atan2",
"band",
"bit32.arshift",
"bit32.band",
"bit32.bnot",
"bit32.bor",
"bit32.btest",
"bit32.bxor",
"bit32.extract",
"bit32.lrotate",
"bit32.lshift",
"bit32.replace",
"bit32.rrotate",
"bit32.rshift",
"bnot",
"bor",
"btest",
"bxor",
"byte",
"ceil",
"char",
"cos",
"cosh",
"deg",
"dump",
"exp",
"extract",
"find",
"floor",
"fmod",
"format",
"frexp",
"gmatch",
"gsub",
"ldexp",
"len",
"log",
"log10",
"lower",
"lrotate",
"lshift",
"match",
"math.abs",
"math.acos",
"math.asin",
"math.atan",
"math.atan2",
"math.ceil",
"math.cos",
"math.cosh",
"math.deg",
"math.exp",
"math.floor",
"math.fmod",
"math.frexp",
"math.huge",
"math.ldexp",
"math.log",
"math.log10",
"math.max",
"math.min",
"math.modf",
"math.pi",
"math.pow",
"math.rad",
"math.random",
"math.randomseed",
"math.sin",
"math.sinh",
"math.sqrt",
"math.tan",
"math.tanh",
"max",
"min",
"modf",
"pow",
"rad",
"random",
"randomseed",
"rep",
"replace",
"reverse",
"rrotate",
"rshift",
"shift"}
