V-REP on Docker
gvgramazio
V-REP on Docker
Post by gvgramazio »
Hi, I'm trying to build a docker image with all the requirements to run v-rep and I have some troubles. This is what I have right now:
FROM ubuntu:16.04
RUN apt-get update && apt-get -y install \
      curl \
      sudo
# Replace 1000 with your user / group id
RUN export uid=1000 gid=1000 && \
    mkdir -p /home/developer && \
    echo "developer:x:${uid}:${gid}:Developer,,,:/home/developer:/bin/bash" >> /etc/passwd && \
    echo "developer:x:${uid}:" >> /etc/group && \
    echo "developer ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/developer && \
    chmod 0440 /etc/sudoers.d/developer && \
    chown ${uid}:${gid} -R /home/developer
USER developer
ENV HOME /home/developer
RUN cd /home/developer && \
    curl http://coppeliarobotics.com/files/V-REP_PRO_EDU_V3_5_0_Linux.tar.gz --output vrep.tar.gz && \
    tar -xzf vrep.tar.gz && \
    rm vrep.tar.gz
But if I run `./vrep.sh` in the V-REP directory I encounter an error of missing libraries. If I run `./libLoadErrorCheck.sh ` I have the following output.
	linux-vdso.so.1 =>  (0x00007ffdac474000)
	liblua5.1.so (0x00007fa23a8e5000)
	libqscintilla2.so.9 (0x00007fa239324000)
	libQt5OpenGL.so.5 (0x00007fa2390cd000)
	libQt5Widgets.so.5 (0x00007fa23889c000)
	libQt5Gui.so.5 (0x00007fa2380ef000)
	libQt5SerialPort.so.5 (0x00007fa237ed6000)
	libQt5Network.so.5 (0x00007fa237b45000)
	libQt5Core.so.5 (0x00007fa23740d000)
	libGL.so.1 => not found
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fa2371f0000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fa236e6e000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fa236b65000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fa23694f000)
	libc.so.6 This application failed to start because it could not find or load the Qt platform plugin "xcb"
in "".
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Reinstalling the application may fix this problem.
./vrep.sh: line 33:   543 Aborted                 (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
=> /lib/x86_64-linux-gnu/libc.so.6 (0x00007fa236585000)
	libQt5PrintSupport.so.5 (0x00007fa236317000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fa2360fd000)
	libicui18n.so.56 (0x00007fa235c64000)
	libicuuc.so.56 (0x00007fa2358ac000)
	libicudata.so.56 (0x00007fa233ec9000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fa233cc1000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fa233abd000)
	/lib64/ld-linux-x86-64.so.2 (0x00007fa23a7eb000)
	libgthread-2.0.so.0 => not found
	libglib-2.0.so.0 => not found
What dependancies I'm missing? I've found nothing on coppeliarobotics.com. If I solve these dependencies with
apt-get -y install libgl1-mesa-glx libglib2.0-0
V-REP doesn't run. The error this time is:
in "".
Re: V-REP on Docker
Not sure... can you confirm that you have platforms/libqxcb.so present?
gvgramazio
Re: V-REP on Docker
Sorry if I didn't reply to this message before but it wasn't on my subscriptions. I've solved the docker problem using the following docker file:
FROM ubuntu:16.04
RUN apt-get update && apt-get install -y \
  wget \
  libglib2.0-0  \
  libgl1-mesa-glx \
  xcb \
  "^libxcb.*" \
  libx11-xcb-dev \
  libglu1-mesa-dev \
  libxrender-dev \
  libxi6 \
  libdbus-1-3 \
  libfontconfig1 \
  xvfb \
  && rm -rf /var/lib/apt/lists/*
RUN wget http://coppeliarobotics.com/files/V-REP_PRO_EDU_V3_5_0_Linux.tar.gz
RUN tar -xf V-REP_PRO_EDU_V3_5_0_Linux.tar.gz
RUN apt-get remove -y wget
RUN echo 'export QT_DEBUG_PLUGINS=1' >> ~/.bashrc
RUN echo 'export PATH=/V-REP_PRO_EDU_V3_5_0_Linux/:$PATH' >> ~/.bashrc
It works fine except for one thing: if I start V-REP even in headless mode it gives me problems because there is no screen. This should be an issue due to Qt and a possible workaround is to launch V-REP with xvfb that fakes a screen.
I've loaded this on github and an automatic build on docker hub. Maybe it could be helpful to someone.
macieksz@pro.onet.pl
Re: V-REP on Docker
Post by macieksz@pro.onet.pl »
I tried to run coppelia in headless mode from inside docker but failed(even tried to use the same dockerfile above)
./coppeliaSim.sh -h
[CoppeliaSimClient] loading the CoppeliaSim library...
[CoppeliaSimClient] done.
[CoppeliaSimClient:loadinfo] launching CoppeliaSim...
[CoppeliaSim:loadinfo] CoppeliaSim V4.1.0., (rev. 1), flavor: 1
[CoppeliaSim:loadinfo] Legacy machine ID: 51B6-94EB-B7C3-9CEC-F7E3-6D1D
[CoppeliaSim:loadinfo] Machine ID: 9B11-736C-C667-0000-55AE-0101
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, webgl, xcb.
./coppeliaSim.sh: line 35: 52 Aborted (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
Do you have any solution for that?
Why Coppelia use qt5 in headless mode, i tried to reinstall the qt5 inside the docker but did not work!
I am using this image
ros:melodic-ros-base-bionic
gvgramazio
Re: V-REP on Docker
Hi @macieksz,
You should try tu run it with xvfb-run. More info on the repository page referenced above.
Re: V-REP on Docker
I already did that before asking on forum:
Here is the same output:
root@40ce36d83bb2:/coppelia_sim#: xvfb-run ./coppeliaSim.sh -h
[CoppeliaSim:loadinfo] Machine ID: D309-736C-98C3-0000-55AE-0101
./coppeliaSim.sh: line 35: 67 Aborted (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
Re: V-REP on Docker
The solution is
RUN rm libcoppeliaSim.so
RUN mv libcoppeliaSimHeadless.so libcoppeliaSim.so
https://www.coppeliarobotics.com/helpFi ... ndLine.htm
and use ./coppeliaSim.sh -h and it works
