Rotation Matrix from sensor to MATLAB
codycichosz
Post by codycichosz »
I am using MATLAB to control my scene in CoppeliaSim. I am currently trying to attach a proximity sensor to a UR10 and if an object is detected, transform the detected object position with respect to the UR10 frame, not the sensor frame. This is to determine where the detected object is relative to the robot for collision avoidance.
I tried following the below help file as it lists the rotation equation. This helps as it shows the rotation equation.
https://www.coppeliarobotics.com/helpFi ... Angles.htm
I also tried following this topic thread, but my rotation matrix is different and do not know where theirs came from.
https://forum.coppeliarobotics.com/view ... ?f=9&t=975
The problem I am having is, depending on the orientation of my sensor, I receive correct or wrong positions transformations. Below is a link to a simplified scene and MATLAB code. I use the proxy sensor to detect a cuboid, and a dummy grab the correct absolute detected position. The output in MATLAB is supposed to be the absolute position of the detected point. In the current configuration, the position will read correctly. As soon as I rotate the sensor along its Z axis, it reads a different detected position (I.e. [Alpha, beta, gamma] = [-90, 0, 0])
https://app.box.com/s/mbgnoz7uxew1om1wsvi2fxgfr50oadu1
Thanks for the help in advance!
Cody
Re: Rotation Matrix from sensor to MATLAB
Hello Cody,
before trying to do frame/coordinate transformations from Matlab, make sure it is working from within CoppeliaSim. In CoppeliaSim you have many matrix and transformation related functions. Once it is working well or as expected in CoppeliaSim, do the same on Matlab side. But best and easiest is probably to directly provide Matlab with the transformed data. For that, simply create a small script function, that you will call from Matlab via simxCallScriptFunction. E.g. to express a point detected by a proximity sensor in absolute coordinates:
function readProxSensor(inInts,inFloats,inStrings,inBuffer)
    local proxSensorHandle=inInts[1]
    local detectedPoint={}
    local m=sim.getObjectMatrix(proxSensorHandle,-1)
    local r,dist,detectedPoint,objHandle,normalVector=sim.readProximitySensor(proxSensorHandle)
    if r>0 then
        detectedPoint=sim.multiplyVector(m,detectedPoint)
    return {},detectedPoint,{},''
codycichosz
Thank you so much! This works perfect. This reduces any error in my calculations.
Cheers!
