Retrieving Object position/size/etc from Remote API
engharat
Post by engharat »
I hope to not bother anyone with such a question: I know it can be done but I have some troubles figuring myself how to do that.
Basically I've linked V-rep with Matlab. The link is okey, as I can run the matlab test.m
What I have to do now is to send to Matlab the list of object in the scene,their type, their position and their size. For example I'm filling the scene with some walls and a robot; I have to send the walls position and width, height,etc to matlab in order to perform some calculations,and the robot status. Then matlab will send back some results.
Re: Retrieving Object position/size/etc from Remote API
You will have to:
1) Retrieve the handle of your objects. Use something like this (C/C++ example):
int objHandle;
if (simxGetObjectHandle("TheNameOfMyObject",&objHandle,simx_opmode_oneshot_wait)==simx_error_noerror)
    // Here I have the handle of my object!
2) Assign a new position/orientation to your objects. Something like this:
float newPos[3]={x,y,z};
simxSetObjectPosition(objHandle,-1,newPos,simx_opmode_oneshot);
Refer to simxGetObjectHandle and simxSetObjectPosition
engharat
Post by engharat »
Hi I'm now stuck at how to get ibject size, i.e. bounding box size. I have to pass to matlab floor and walls sizes. Thanks
You cannot access the bounding box size of objects as of V-REP 3.0.1
V-REP 3.0.2, to be released around mid-March 2013 will have a mechanism for that ( simGetObjectFloatParameter with second argument 15-20)
In the mean time, refer also to this post:
