asti robot matlab api joint does not move
thoriqsalafi
Post by thoriqsalafi » 09 Mar 2014, 09:12
hi,
i am using asti robot to move the joint from matlab, here is the matlab code
function simpleTest()
	disp('Program started');
	%vrep=remApi('remoteApi','extApi.h'); % using the header (requires a compiler)
	vrep=remApi('remoteApi'); % using the prototype file (remoteApiProto.m)
	vrep.simxFinish(-1); % just in case, close all opened connections
	clientID=vrep.simxStart('127.0.0.1',19999,true,true,5000,5);
	try
		if (clientID>-1)
            [retVal,leftArmJoint]=vrep.simxGetObjectHandle(clientID,'leftArmJoint1',vrep.simx_opmode_oneshot_wait);
            check(vrep,retVal, 'failed to get object', 'got object');
			[res,objs]=vrep.simxGetObjects(clientID,vrep.sim_handle_all,vrep.simx_opmode_oneshot_wait);
            [retVal]=vrep.simxSetJointTargetPosition(clientID,leftArmJoint,-(pi/2),vrep.simx_opmode_oneshot);
            check(vrep,retVal, 'failed to set joint', 'set joint');
			if (res==vrep.simx_error_noerror)
				fprintf('Number of objects in the scene: %d\n',length(objs));
				fprintf('Remote API function call returned with error code: %d\n',res);
			vrep.simxFinish(clientID);
			disp('Failed connecting to remote API server');
		vrep.delete(); % call the destructor!
	catch retVal
	end;
	disp('Program ended');
function check(vrep, retVal, textError, textNoError)
     if (retVal==vrep.simx_error_noerror)
         disp(textNoError);
        disp(textError);
the asti code is this
simExtRemoteApiStart(19999)
	asti=simGetObjectHandle("Asti")
	lFoot=simGetObjectHandle("leftFootTarget")
	rFoot=simGetObjectHandle("rightFootTarget")
	lPath=simGetObjectHandle("leftFootPath")
	rPath=simGetObjectHandle("rightFootPath")
	lPathLength=simGetPathLength(lPath)
	rPathLength=simGetPathLength(rPath)
	ui=simGetUIHandle("astiUserInterface")
	simSetUIButtonLabel(ui,0,simGetObjectName(asti).." user interface")
	dist=0
	correction=0.0305
	minVal={0,			-- Step size
			0,			-- Walking speed
			-math.pi/2,	-- Neck 1
			-math.pi/8,	-- Neck 2
			-math.pi/2,	-- Left shoulder 1
			0,			-- Left shoulder 2
			-math.pi/2,	-- Left forearm
			-math.pi/2,	-- Right shoulder 1
			0,			-- Right shoulder 2
			-math.pi/2}	-- Right forearm
	rangeVal={	2,			-- Step size
				0.8,		-- Walking speed
				math.pi,	-- Neck 1
				math.pi/4,	-- Neck 2
				math.pi/2,	-- Left shoulder 2
				math.pi/2,	-- Right shoulder 2
	uiSliderIDs={3,4,5,6,7,8,9,10,11,12}
	relativeStepSize=1
	nominalVelocity=0.4
	neckJoints={simGetObjectHandle("neckJoint0"),simGetObjectHandle("neckJoint1")}
	leftArmJoints={simGetObjectHandle("leftArmJoint0"),simGetObjectHandle("leftArmJoint1"),simGetObjectHandle("leftArmJoint2")}
	rightArmJoints={simGetObjectHandle("rightArmJoint0"),simGetObjectHandle("rightArmJoint1"),simGetObjectHandle("rightArmJoint2")}
	-- Now apply current values to the user interface:
	simSetUISlider(ui,uiSliderIDs[1],(relativeStepSize-minVal[1])*1000/rangeVal[1])
	simSetUISlider(ui,uiSliderIDs[2],(nominalVelocity-minVal[2])*1000/rangeVal[2])
	simSetUISlider(ui,uiSliderIDs[3],(simGetJointPosition(neckJoints[1])-minVal[3])*1000/rangeVal[3])
	simSetUISlider(ui,uiSliderIDs[4],(simGetJointPosition(neckJoints[2])-minVal[4])*1000/rangeVal[4])
	simSetUISlider(ui,uiSliderIDs[5],(simGetJointPosition(leftArmJoints[1])-minVal[5])*1000/rangeVal[5])
	simSetUISlider(ui,uiSliderIDs[6],(simGetJointPosition(leftArmJoints[2])-minVal[6])*1000/rangeVal[6])
	simSetUISlider(ui,uiSliderIDs[7],(simGetJointPosition(leftArmJoints[3])-minVal[7])*1000/rangeVal[7])
	simSetUISlider(ui,uiSliderIDs[8],(simGetJointPosition(rightArmJoints[1])-minVal[8])*1000/rangeVal[8])
	simSetUISlider(ui,uiSliderIDs[9],(simGetJointPosition(rightArmJoints[2])-minVal[9])*1000/rangeVal[9])
	simSetUISlider(ui,uiSliderIDs[10],(simGetJointPosition(rightArmJoints[3])-minVal[10])*1000/rangeVal[10])
simHandleChildScript(sim_handle_all_except_explicit)
-- Read desired values from the user interface:
relativeStepSize=minVal[1]+simGetUISlider(ui,uiSliderIDs[1])*rangeVal[1]/1000
nominalVelocity=minVal[2]+simGetUISlider(ui,uiSliderIDs[2])*rangeVal[2]/1000
simSetJointTargetPosition(neckJoints[1],minVal[3]+simGetUISlider(ui,uiSliderIDs[3])*rangeVal[3]/1000)
simSetJointTargetPosition(neckJoints[2],minVal[4]+simGetUISlider(ui,uiSliderIDs[4])*rangeVal[4]/1000)
simSetJointTargetPosition(leftArmJoints[3],minVal[7]+simGetUISlider(ui,uiSliderIDs[7])*rangeVal[7]/1000)
simSetJointTargetPosition(rightArmJoints[1],minVal[8]+simGetUISlider(ui,uiSliderIDs[8])*rangeVal[8]/1000)
simSetJointTargetPosition(rightArmJoints[2],minVal[9]+simGetUISlider(ui,uiSliderIDs[9])*rangeVal[9]/1000)
simSetJointTargetPosition(rightArmJoints[3],minVal[10]+simGetUISlider(ui,uiSliderIDs[10])*rangeVal[10]/1000)
-- Get the desired position and orientation of each foot from the paths (you can also use a table of values for that):
t=simGetSimulationTimeStep()*nominalVelocity
dist=dist+t
lPos=simGetPositionOnPath(lPath,dist/lPathLength)
lOr=simGetOrientationOnPath(lPath,dist/lPathLength)
p=simGetPathPosition(rPath)
rPos=simGetPositionOnPath(rPath,(dist+correction)/rPathLength)
rOr=simGetOrientationOnPath(rPath,(dist+correction)/rPathLength)
-- Now we have the desired absolute position and orientation for each foot.
-- Now transform the absolute position/orientation to position/orientation relative to asimo
-- Then modulate the movement forward/backward with the desired "step size"
-- Then transform back into absolute position/orientation:
astiM=simGetObjectMatrix(asti,-1)
astiMInverse=simGetInvertedMatrix(astiM)
m=simMultiplyMatrices(astiMInverse,simBuildMatrix(lPos,lOr))
m[8]=m[8]*relativeStepSize
m=simMultiplyMatrices(astiM,m)
lPos={m[4],m[8],m[12]}
lOr=simGetEulerAnglesFromMatrix(m)
m=simMultiplyMatrices(astiMInverse,simBuildMatrix(rPos,rOr))
rPos={m[4],m[8],m[12]}
rOr=simGetEulerAnglesFromMatrix(m)
-- Finally apply the desired positions/orientations to each foot
-- We simply apply them to two dummy objects that are then handled
-- by the IK module to automatically calculate all leg joint desired values
-- Since the leg joints operate in hybrid mode, the IK calculation results
-- are then automatically applied as the desired values during dynamics calculation
simSetObjectPosition(lFoot,-1,lPos)
simSetObjectOrientation(lFoot,-1,lOr)
simSetObjectPosition(rFoot,-1,rPos)
simSetObjectOrientation(rFoot,-1,rOr)
i tried but the result is this
asti
Program started
Running Matlab win64
make sure you use the corresponding remoteApi library
(i.e. 32bit Matlab will not work with 64bit remoteApi, and vice-versa)
got object
failed to set joint
Number of objects in the scene: 80
Program ended
anyone can help me to make the joint move from matlab?
thank you!
Re: asti robot matlab api joint does not move
Post by coppelia » 09 Mar 2014, 22:37
first of all, if you are running the 64bit version of Matlab, use this code instead (that code will be available in the next release (V3.1.1)), it corrects for a bug that affects 4-5 Matlab functions, including simxSetJointTargetPosition.
Then, you should remember that if you use the operation mode simx_opmode_oneshot, the command is non-blocking and will return immediately. It will take a few miliseconds until the command is sent to V-REP. If you kill the connection directly after sending the command, it might be that the command never arrives. To make sure that command has arrived before killing the connection, you could simple call: simxGetPingTime.
Third, in the Asti model, the joints are handled via inverse kinematics. If you try to interfere while inverse kinematics is also trying to set the joint position, you might get very strange results. You will have to disable the inverse kinematics, or simply remove the 2 IK groups. Then, you will have to set all joints to force/torque mode, enable the motors and position control.
Try maybe starting with a simple example, with a single joint, and extend from there.
thoriqsalafi
Post by thoriqsalafi » 10 Mar 2014, 05:05
thanks admin for the perfect reply, I managed to get the joints move!
