Upper Velocity Limit by a Joint control loop
qiushi.ji
Post by qiushi.ji »
Hi Marc,
I'm now trying writing program in joint callback script instead of child script because of the delay time every simulation time.
One question actually I've just forgot asking before weeks ago:
If a joint can reach a speed of e.g. 3600°, why the max. number of "Upper velocity limit" is 1145.92 in Joint Dynamic Properties? It just jumps back to 1145.92 if I enter a bigger number.
One little question, I'm always confused myself about the word "simulation time" or "simulation step" which present dt and dt/10times in physic engine... how to say it correctly? is it simulation time = simulation step/10?
Cheers,
Ji
Re: Upper Velocity Limit by a Joint control loop
Hello Ji,
the Upper velocity limit is used when the control loop is enabled, when the position control mode or spring-damper mode is enabled. In that case it doesn't make sense to allow for higher velocities.
When you write your own controller via a joint callback script, then you are free to ignore that upper limit. Your callback script is handed that upper limit in the first line, last value:
init,revolute,cyclic,jointHandle,passCnt,totalPasses,currentPos,targetPos,errorValue,effort,dynStepSize,lowLimit,highLimit,targetVel,maxForceTorque,velUpperLimit=...
You can use the variable velUpperLimit, or you can ignore it and simply return the velocity that you wish to apply:
-- Following data must be returned to V-REP:
return forceOrTorqueToApply,velocityToApply
Then you have:
  • simulation time: is not constant and represents the simulation progression. By default, it varies like: 0, 50ms, 100ms, 150ms, 200ms, etc.
  • simulation step: is by default what happens during 50ms of simulation. In each simulation step the main script is called exactly once.
  • simulation time step: is by default 50 ms. You can change it here.
  • dynamic time step: is by default 5ms. By default a simulatioj step is composed by 10 dynamic simulation steps. You can change the dynamic time step here.
xxm
Post by xxm »
Hi,coppelia
When the control loop is enabled, when the position control mode or spring-damper mode is enabled,do you have any way to improve upper velocity limit? when velocity is 1000deg/s,my robot is 1m/s,but I want my robot run faster,for example 5m/s,10m/s.I do not know what should I do .
Look forward to your replay!
