Torque control
sam3891
Re: Torque control
Post by sam3891 »
How does this work then in the joint space, where a torque vector is only one value?
I am trying to generate a custom torque controller in MATLAB by following your suggestion, but on the VREP side, the function simAddForceAndTorque requires 3 coordinates per joint, whereas MATLAB generates one joint torque only. (I am using KUKA_LBR_14_R820)
Also, what should be the handle for this function ('simAddForceAndTorque') for this model, let's say for joint3? I have chosen:
handle = simGetObjectHandle('KUKA_LBR_14_R820_link3'), is this right?
coppelia wrote:yes, that is correct. You could for instance do:
On the remote API client side (e.g. in C/C++):
float forceVectorToApply[3]; // a force vector initialized to what you want
simxSetStringSignal(clientId,"myVector",(simxChar*)forceVectorToApply,3*sizeof(float),simx_opmode_oneshot);
Inside of a non-threaded child script:
	lastVector={0,0,0}
	local signal=simGetStringSignal('myVector')
	if signal then
		lastVector=simUnpackFloats(signal)
	-- Apply your vector here:
	simAddForceAndTorque(shapeHandle,lastVector)
erik
Re: Torque control
Post by erik »
Hi Sam,
if you send me an e-mail I can reply with a sample file where I tried different methods to apply joint torques, including a Matlab file that sends the desired torques. The case study I did: simple 3dof arm where I wanted to compute and apply the torques to compensate for gravity (i.e. the arm should do nothing when running the simulation).
Erik
Re: Torque control
In next release, there will be a much more in-depth description how to control a joint. We have uploaded the page already, it can be found here, but some html links might not yet be working.
sam3891
Re: Torque control
Post by sam3891 »
I want to implement an application on the "KUKA_LBR_iiwa_14_R820", where I calculate torques on the MATLAB side and send them across to VREP using simxSetJointForce and simxSetJointVelocity.
for i=1:7
                if( torque(i)>0.0 )
                    velocity(i) = 9999.0;
                elseif (torque(i) <0.0)
                    velocity(i) = -9999.0;
                    velocity(i) = 0.0;
for i=1:7
                vrep.simxSetJointTargetVelocity(clientID,jointHandles(i),velocity(i),vrep.simx_opmode_oneshot);
for i=1:7
                vrep.simxSetJointForce(clientID,jointHandles(i),abs(torque(i)),vrep.simx_opmode_oneshot);
On the V-Rep side, I have enabled a custom joint control loop in the joint dynamic properties, in order to add damping:
cVel=simGetObjectFloatParameter(jointHandle,2012)
forceOrTorqueToApply=maxForceTorque-(-300*cVel)
return forceOrTorqueToApply,targetVel
1. Is this the right way to do it?
2. Also, in order to ensure that the torque computed by MATLAB is accurately set in VREP, I would like to run the joint control callback script a few times and then communicate with MATLAB. For this I have set the ODE time step to 1ms and the VREP simulation time step to 5ms. Is this correct? Or is there another way to go about this?
I would really appreciate some help.
Thanks!
Re: Torque control
please read this section first, there are many things you can do wrong if you try to control a joint from an external application.
sam3891
Re: Torque control
Post by sam3891 »
I have the code as per what you said. So my question again is:
sam3891 wrote:Hi,
for i=1:7
                if( torque(i)>0.0 )
                    velocity(i) = 0.0;
for i=1:7
for i=1:7
        vrep.simxSynchronousTrigger(clientID);
2. Also, in order to ensure that the torque computed by MATLAB is accurately set in VREP, I would like to run the joint control callback script a few times and then communicate with MATLAB. For this I have set the ODE time step to 1ms and the VREP simulation time step to 1ms. Is this correct? Or is there another way to go about this? Is there a possibility to modify the variable 'totalPasses' in the joint control callback script?
Thanks!
Re: Torque control
1) That sounds correct (if the other requirements discussed in the link I sent previously are respected)
2) Why would you like the joint control callback to be run a few times before applying values from Matlab? Not sure I understand . But as you mention it, it is good to set the same value for the simulation time step and the physics engine time step.
In a first step, I would try without the callback script that you use for additional damping. Currently you are mixing things, and many things can go wrong. Try to go step-by-step. And see until what point it works, or at which point it stops working.
sam3891
Re: Torque control
Post by sam3891 »
I want to ensure that the torque being communicated over by MATLAB to VREP is applied without lag. So I want to run the joint script several times per simulation step.
Re: Torque control
I still don't understand it. Things communicated from Matlab to V-REP will be applied with a lag. Always. Because Matlab is an external application. But in terms of simulation time, if you enabled the synchronous mode, then you can make sure that things are applied in each simulation step. e.g.:
  • send torque value
  • trigger next simulation step
  • send torque value
  • send torque value
  • send torque value
sam3891
Re: Torque control
Post by sam3891 »
Hi admin,
Thank you for your patience.
So this is what I was thinking of:
Calculate torque in MATLAB
simxSetJointForce
Trigger
On V-Rep Side, in a joint ctrl callback script:
Torque = maxTorque (this is what MATLAB gives) - ( damping factor * current velocity)
Apply this calculated torque several times, for increased precision
