bipedal robot
efrianto
bipedal robot
Post by efrianto » 01 Dec 2014, 15:03
I have work in my thesis project to make the simulation of bipedal robot in V-Rep simulation. Here is my bipedal robot looks like:
Image. Now, i'm in progress to make the behaviour for the bipedal robot, such as walking forward, move left or right, etc. But, i have problem in defining some variables that i need for the formula calculation of bipedal robot. I want to make my bipedal robot in initial position standing with the distance between joint 5 and joint 9, also distance between joint 6 and joint 10 is h1/h2, like i show in my picture below:
Can someone help me how to keep joint 5 and joint 9 stay in distance of h1 or joint 6 and to joint 10 in distance of h2?
Here is i attached also my program:
simSetThreadSwitchTiming(2) -- Default timing for automatic thread switching
simDelegateChildScriptExecution()
rightfoot = simGetObjectHandle ('Dummy2')
leftfoot = simGetObjectHandle ('Dummy')
motor_2		=	simGetObjectHandle('leftmotor2_1')
motor_4		=	simGetObjectHandle('leftmotor2_2')
motor_6		=	simGetObjectHandle('leftmotor2_3')
motor_8		=	simGetObjectHandle('leftmotor2_4')
motor_10	=	simGetObjectHandle('leftmotor2_5')
motor_12	=	simGetObjectHandle('leftmotor2_6')
motor_1		=	simGetObjectHandle('rightmotor2_1')
motor_3		=	simGetObjectHandle('rightmotor2_2')
motor_5		=	simGetObjectHandle('rightmotor2_3')
motor_7		=	simGetObjectHandle('rightmotor2_4')
motor_9		=	simGetObjectHandle('rightmotor2_5')
motor_11	=	simGetObjectHandle('rightmotor2_6')
--input = simGetUIHandle('Movement')
--offset= 107
--phi= 18
beta_stand= 1.047
beta_liftfoot= 1.57
[color=#FF0040]l1_1d= simGetObjectPosition(motor_5,motor_7)
l1_2d= simGetObjectPosition(motor_7,motor_9)
l2_1d= simGetObjectPosition(motor_6,motor_8)
l2_2d= simGetObjectPosition(motor_8,motor_10)
l1_1=math.sqrt((l1_1d[1]^2)+(l1_1d[2]^2)+(l1_1d[3]^2))
l1_2=math.sqrt((l1_2d[1]^2)+(l1_2d[2]^2)+(l1_2d[3]^2))
l2_1=math.sqrt((l2_1d[1]^2)+(l2_1d[2]^2)+(l2_1d[3]^2))
l2_2=math.sqrt((l2_2d[1]^2)+(l2_2d[2]^2)+(l2_2d[3]^2))[/color]
while (simGetSimulationState()~=sim_simulation_advancing_abouttostop) do
--initial = simGetUIEventButton(input)
--if(initial == 3 )
--then
--initial position
teta1= beta_stand/2
teta2= beta_stand/2
[color=#FF0040]h1d= (l1_1+l1_2)*(math.cos(teta1))--distance between rightmotor2_3 with rightmotor2_5
h2d= (l2_1+l2_2)*(math.cos(teta2))--distance between leftmotor2_3 with leftmotor2_5[/color]
alpha1= teta1
alpha2= teta2
gamma1= teta1
gamma2= teta2
[color=#FF0040]h1={0,0,h1d}
h2={0,0,h2d}[/color]
[color=#FF0000]simSetObjectPosition(motor_5,motor_9,h1d)
simSetObjectPosition(motor_6,motor_10,h2d)[/color]
simSetJointPosition(motor_1,1.838323549)
simSetJointPosition(motor_2,3.41037182)
simSetJointPosition(motor_3,2.621787345)
simSetJointPosition(motor_4,2.621787345)
simSetJointPosition(motor_5,(2.621787345-alpha1))
simSetJointPosition(motor_6,(2.621787345-alpha2))
simSetJointPosition(motor_7,(2.621787345+beta_stand))
simSetJointPosition(motor_8,(2.621787345+beta_stand))
simSetJointPosition(motor_9,2.621787345-gamma1)
simSetJointPosition(motor_10,2.621787345-gamma2)
simSetJointPosition(motor_11,2.621787345)
simSetJointPosition(motor_12,2.621787345)
--end
--tetat= angle between rightmotor2_3 with reference
--teta1= angle of rightmotor2_3 (beta1/2)
--teta2= angle of leftmotor2_3 (beta2/2)
--gamma1= angle of rightmotor2_5 (teta1+tetat)
--gamma2= angle of leftmotor2_5 (teta2-tetat)
--alpha1= angle of rightmotor2_3 (teta1-tetat)
--alpha2= angle of leftmotor2_3 (teta2+tetat)
--phi1.1=phi1.2=phi2.1=phi2.2= angle to turn right / left
--pos1 = {0.2120, 0.03, 0.0738}
--pos2 = {0.06, 0.03, 0.0738}
--simSetObjectPosition (rightfoot, -1, pos2)
--simSetObjectPosition (leftfoot, -1, pos1)
--end
Re: bipedal robot
Post by coppelia » 01 Dec 2014, 22:12
your question is not clear. Are you talking about a control algorithm? How to keep the distance between the two mentionned joints constant?
This forum will quickly help you for questions regarding V-REP and how to use it. But for control algorithms, you have many many possibilities, and we are no experts for that. Maybe some other user on this forum can help you.
efrianto
Re: bipedal robot
Post by efrianto » 02 Dec 2014, 09:49
yes, i mean How to keep the distance between the two mentioned joints constant?
can i use simSetObjectPosition like in my coding that i have been attached? Thank you
Re: bipedal robot
Post by coppelia » 02 Dec 2014, 21:43
No, you cannot use simSetObjectPosition, otherwise you will break the mechanism. You will have to adjust the joint position (probably simSetJointTargetPosition) by doing some geometric computation.
efrianto
Re: bipedal robot
Post by efrianto » 03 Dec 2014, 09:12
Thanks for the reply. How is i use dummy in every joint? Then i use simGetObjectPosition with the position of the dummy? Is it possible to keep the distance between the two mentioned joints constant? Thank you very much
Re: bipedal robot
Post by coppelia » 03 Dec 2014, 16:44
You can call simGetObjectPosition in order to retrieve the position of your joint:
local pos=simGetObjectPosition(jointHandle,-1)
local xCoord=pos[1]
local yCoord=pos[2]
local zCoord=pos[3]
efrianto
Re: bipedal robot
Post by efrianto » 04 Dec 2014, 08:32
sorry, i am wrong, i mean simSetObjectPosition not simGetObjectPosition. how if i use dummy in every joint then i use the coordinate of the dummy in simSetObjectPosition to keep the distance as i mention before? Thank you
efrianto
Re: bipedal robot
Post by efrianto » 10 Dec 2014, 15:27
I want to ask, i have already written a programming with the logic that i think it's correct. but the simulation doesn't work like i write in the programming, here i attached my programming. Can anyone help me? Thank you very much
--offset= 107
phi= 0.31
beta_stand= 1.05
beta_liftfoot= 2.09
function initial()
	local teta1= beta_stand/2
	local teta2= beta_stand/2
--local h1d= (l1_1+l1_2)*(math.cos(teta1))--distance between rightmotor2_3 with rightmotor2_5
--local h2d= (l2_1+l2_2)*(math.cos(teta2))--distance between leftmotor2_3 with leftmotor2_5
	local alpha1= teta1
	local alpha2= teta2
	local gamma1= teta1
	local gamma2= teta2
--h1={0,0,h1d}
--h2={0,0,h2d}
--simSetObjectPosition(motor_5,motor_9,h1d)
--simSetObjectPosition(motor_6,motor_10,h2d)
	simSetJointPosition(motor_1,1.84)
	simSetJointPosition(motor_2,3.41)
	simSetJointPosition(motor_3,2.62)
	simSetJointPosition(motor_4,2.62)
	simSetJointPosition(motor_5,(2.62-alpha1))
	simSetJointPosition(motor_6,(2.62-alpha2))
	simSetJointPosition(motor_7,(2.66+beta_stand))
	simSetJointPosition(motor_8,(2.62+beta_stand))
	simSetJointPosition(motor_9,2.62-gamma1)
	simSetJointPosition(motor_10,2.62-gamma2)
	simSetJointPosition(motor_11,2.62)
	simSetJointPosition(motor_12,2.62)
end -- initial
function tilt_left()
	local alpha1= teta1
	local alpha2= teta2
	local gamma1= teta1
	local gamma2= teta2
	simSetJointPosition(motor_3,2.62-phi)
	simSetJointPosition(motor_4,2.62-phi)
	simSetJointPosition(motor_11,2.62+phi)
	simSetJointPosition(motor_12,2.62+phi)
end -- tilt_left
function lift_rightfoot()
	local teta1= beta_liftfoot/2
	local tetat=0
	local alpha1= teta1-tetat
	local alpha2= teta2+tetat
	local gamma1= teta1+tetat
	local gamma2= teta2-tetat
	simSetJointPosition(motor_7,(2.66+beta_liftfoot))
end -- lift_rightfoot
function rightfoot_forward()
	local tetat= 0.22
	local teta2=beta_stand/2
	local alpha1= teta1+tetat
	local alpha2= teta2-tetat
	local gamma1= teta1-tetat
	local gamma2= teta2+tetat
end -- rightfoot_forward
function tilt_right()
	local tetat= 0.22
	simSetJointPosition(motor_3,2.62+phi)
	simSetJointPosition(motor_4,2.62+phi)
	simSetJointPosition(motor_11,2.62-phi)
	simSetJointPosition(motor_12,2.62-phi)
end -- tilt_right
function lift_leftfoot()
	local tetat= 0.22
	local teta2=beta_liftfoot/2
	simSetJointPosition(motor_8,(2.62+beta_liftfoot))
end -- lift_leftfoot
function leftfoot_forward()
	local phi = 0.17
	local tetat= 0.22
end -- leftfoot_forward
function tilt_left2()
	local tetat= 0.22
end -- tilt_left2
function lift_rightfoot2()
	local tetat= 0.2198
end -- lift_rightfoot2
function rightfoot_forward2()
	local alpha1= teta1
	local alpha2= teta2
	local gamma1= teta1
	local gamma2= teta2
end -- rightfoot_forward2
function tilt_right2()
	local alpha1= teta1
	local alpha2= teta2
	local gamma1= teta1
	local gamma2= teta2
end -- tilt_right2
input = simGetUIHandle('movement')
input2 = simGetUIHandle('movement')
input3 = simGetUIHandle('movement')
input4 = simGetUIHandle('movement')
input5 = simGetUIHandle('movement')
input6 = simGetUIHandle('movement')
input7 = simGetUIHandle('movement')
input8 = simGetUIHandle('movement')
input9= simGetUIHandle('movement')
input10= simGetUIHandle('movement')
input11= simGetUIHandle('movement')
--l1_1d= simGetObjectPosition(motor_5,motor_7)
--l1_2d= simGetObjectPosition(motor_7,motor_9)
--l2_1d= simGetObjectPosition(motor_6,motor_8)
--l2_2d= simGetObjectPosition(motor_8,motor_10)
--l1_1=math.sqrt((l1_1d[1]^2)+(l1_1d[2]^2)+(l1_1d[3]^2))
--l1_2=math.sqrt((l1_2d[1]^2)+(l1_2d[2]^2)+(l1_2d[3]^2))
--l2_1=math.sqrt((l2_1d[1]^2)+(l2_1d[2]^2)+(l2_1d[3]^2))
--l2_2=math.sqrt((l2_2d[1]^2)+(l2_2d[2]^2)+(l2_2d[3]^2))
dom = true
if(dom == true)
then
	print('start')
	initialID = simGetUIButtonProperty(input,3)
	tilt_leftID = simGetUIButtonProperty(input2,4)
	lift_rightfootID = simGetUIButtonProperty(input3,5)
	rightfoot_forwardID = simGetUIButtonProperty(input4,6)
	tilt_rightID = simGetUIButtonProperty(input5,7)
	lift_leftfootID = simGetUIButtonProperty(input6,8)
	leftfoot_forwardID = simGetUIButtonProperty(input7,9)
	forward_moveID = simGetUIButtonProperty(input8,10)
	tilt_left2ID = simGetUIButtonProperty(input9,11)
	lift_rightfoot2ID = simGetUIButtonProperty(input10,12)
	rightfoot_forward2ID = simGetUIButtonProperty(input11,13)
	if(initialID == 8536 ) then
		initial()
	if(tilt_leftID == 8536) then
		tilt_left()
	if(lift_rightfootID == 8536) then
		lift_rightfoot()
	if(rightfoot_forwardID == 8536) then
		rightfoot_forward()
	if(tilt_rightID == 8536) then
		tilt_right()
	if(lift_leftfootID == 8536) then
		lift_leftfoot()
	if (leftfoot_forwardID == 8536) then
		leftfoot_forward()
	if (tilt_left2ID == 8536) then
		tilt_left2()
	if (lift_rightfoot2ID == 8536) then
		lift_rightfoot2()
	if(rightfoot_forward2ID == 8536) then
	s=0
	if (forward_moveID == 8536) then
		dom = false
		if(s==0)then
		initial()
		j5= simGetJointPosition(motor_5)
		j6= simGetJointPosition(motor_6)
		j7= simGetJointPosition(motor_7)
		j8= simGetJointPosition(motor_8)
		j9= simGetJointPosition(motor_9)
		j10= simGetJointPosition(motor_10)
		print((j5 - j5%0.01),(j6 - j6%0.01),(j7 - j7%0.01),(j8 - j8%0.01),(j9 - j9%0.01),(j10 - j10%0.01))
				if(j5<(2.1)and j6<(2.1)and j7<(3.71) and j8<(3.67) and j9<(2.1) and j10<(2.1)) then
				--while(j5>(2.098287345) and j6>(2.098287345) and j7>(3.709752772) and j8>(3.668787345) and j9>(2.098287345) and j10>(2.098287345)) do
				local alpha1= teta1
				local alpha2= teta2
				local gamma1= teta1
				local gamma2= teta2
				elseif (j5>=(2.09)and j6>=(2.09)and j7>=(3.7) and j8>=(3.66) and j9>=(2.09) and j10>=(2.09)) then
				s=1
				print("finish_initial")
		if(s==1) then
		print('masuk')
		tilt_left()
		j3= simGetJointPosition(motor_3)
		j4= simGetJointPosition(motor_4)
		j11= simGetJointPosition(motor_11)
		j12= simGetJointPosition(motor_12)
				if(j3<(2.3) and j4<(2.3) and j11<(2.93) and j12<(2.93)) then
				local alpha1= teta1
				local alpha2= teta2
				local gamma1= teta1
				local gamma2= teta2
				elseif (j3>=(2.3) and j4>=(2.3) and j11>=(2.93) and j12>=(2.93)) then
				s=2
				print(s)
				print('finish_tilt_left')
		if(s==2)then
		print('masuk2')
		initial()
		print((j5 - j5%0.001),(j6 - j6%0.001),(j7 - j7%0.001),(j8 - j8%0.001),(j9 - j9%0.001),(j10 - j10%0.001))
				local alpha1= teta1
				local alpha2= teta2
				local gamma1= teta1
				local gamma2= teta2
				s=3
				print(s)
				print("finish_initial2")
		if(s==3)then
		print('masuk3')
				simSetJointPosition(motor_5,2.62)
				simSetJointPosition(motor_6,2.62)
				simSetJointPosition(motor_7,2.66)
				simSetJointPosition(motor_8,2.62)
				simSetJointPosition(motor_9,2.62)
				simSetJointPosition(motor_10,2.62)
				print("finish_standing")
--and j8==(3.668787345) and j9==(2.098287345) and j10==(2.098287345)
--and j8<(3.668787345) and j9<(2.098287345) and j10<(2.098287345)
--function initial()
--end
Eric
Re: bipedal robot
Post by Eric » 10 Dec 2014, 20:26
if you want help you need to be more specific on what your question is... saying : the simulation doesn t work and just dropping the code is not going to help you to get help
efrianto
Re: bipedal robot
Post by efrianto » 11 Dec 2014, 08:43
i'm so sorry. I mean in this segment of my code the simulation must move first to initial position, then after that the program will check the position of the joint after finish the checking then the state change from 0 to 1, it prove that initial position has reached. After that with state = 1, the program should be move to the tilt_left postion and the same process with before until the last state = 3 that is standing. But when the simulation start the robot not move like the program said
s=0
      dom = false
      if(s==0)then
      initial()
            local alpha1= teta1
            local alpha2= teta2
            local gamma1= teta1
            local gamma2= teta2
            s=1
      if(s==1) then
      print('masuk')
      tilt_left()
            local alpha1= teta1
            local alpha2= teta2
            local gamma1= teta1
            local gamma2= teta2
            s=2
            print(s)
      if(s==2)then
      print('masuk2')
      initial()
            local alpha1= teta1
            local alpha2= teta2
            local gamma1= teta1
            local gamma2= teta2
            s=3
            print(s)
      if(s==3)then
      print('masuk3')
the robot just move like this:
beside the program in command window has already enter every process until finish but it is not the same with simulation.
Thank you very much
