V-REP Path planing
AsadAli
V-REP Path planing
Post by AsadAli »
I want to know which path planning algorithm is used in path planning module, and is it possible to change the back-end algorithm used to compute the path.
Moreover Any video tutorial about collision detection module
Re: V-REP Path planing
A RRT algorithm is used.
If you want to implement a different path planning algorithm, best would be to take the approach to create a plugin that exports new Lua commands for path planning: this would be the easiest, and the cleanest option.
AsadAli
Post by AsadAli »
Is it RRT*, and Please elaborate your suggestion .
It is RRT connect, or a variation of it (depending on the type of path planning).
What I suggested with the plugin is following:
Once that is done, you can communicate with your plugin via the custom lua functions you have registered. So your code could look like:
taskHandle=simExt_createPlanningTask()
simExt_addRobotCollisionObject(taskHandle,robotObject1Handle)
simExt_addRobotCollisionObject(taskHandle,robotObject2Handle)
simExt_addObstacleCollisionObject(taskHandle,obstacleCollectionHandle)
simExt_addRobotPlanningJoint(taskHandle,robotJoint1Handle)
simExt_addRobotPlanningJoint(taskHandle,robotJoint2Handle)
simExt_setPlanningParameters(taskHandle,stepSize,...)
calculatedPath=simExt_findPath(taskHandle,{joint1Start,joint2Start,...},{joint1Goal,joint2Goal,...})
