Is it possible to select multiple objects in the scene hierarchy without selecting them all individually? The normal way this is done is with Shift+Click, but in V-REP Shift-Click works the same as Ctrl-Click (only adds one new object to your selection, rather than selecting all between).
I have about 50 objects that I would like to select, so I can delete/move them all at once, but it will take a while to click each one individually. Is there some way I could select them all? (without selecting everything else) So far I haven't found a way to do it. If it makes things easier, they are all nested within one dummy object, but if I delete that object, it just moves them up in the hierarchy instead of deleting them.
Select Groups of Objects in the Scene Hierarchy
Re: Select Groups of Objects in the Scene Hierarchy
Nevermind, figured it out. Shift+Click and drag does the trick
