I'm currently learning from a tutorial on vision servoing. The vision sensor will move based on its detection on a certain blob. A Yaw and Pitch revolute joint was used to tilt the sensor. But what if I choose to use a spherical joint?Since it covers all sections of an area sweep.
Regards,
Danny
Vision Sensor - Spherical or Revolute Joint
Re: Vision Sensor - Spherical or Revolute Joint
Hello Danny,
you can of course also use a spherical joint, but be aware that you can't control your spherical joint dynamically (i.e. it will act as a non-actuated joint).
But in the end, using two revolute joints, as is done in reality, is probably the better option.
I see, ok then I'll use revoluting roll and pitch instead. Thanks!coppelia wrote:Hello Danny,
Danny
