API for precise dynamics engine properties?
manip
Post by manip »
Is there any way to programmatically adjust dynamics engine parameters, such as vortex time step, instead of using GUI dialog?
I wish to work with ROS and run multiple simulations with different fidelity setup. I have tried to change the values of sim_floatparam_simulation_time_step and sim_intparam_speedmodifier, but they can't affect the value of sim_intparam_dynamic_step_divider which I think is related to the dynamics engine time step.
Re: API for precise dynamics engine properties?
we have added a new float parameter constant: sim_floatparam_dynamic_step_size
You can then set the step size of the currently selected physics engine only if simulation is stopped, and if a custom configuration was selected for the current physics engine.
The change will be available in next release (normally before the end of the year).
manip
Post by manip »
Thanks for your quick response. I really appreciate it.
You are welcome!
We have also added another value, that might come in handy: sim_intparam_dynamic_iteration_count (an integer parameter).
