Hi Coppelia,
I'm asking you a conceptual support.
Do you think that V-REP could be a good simulated experimental platform to simulate a network of hybrid dynamical systems (e.g. a network of mobile robots). I have a few doubts about syncronization of different automatons.
My goal is to perform some experimentations for my Ph.D.
Regards
Roberto
Hybrid Dynamic Systems: is it V-REP a good choice?
Re: Hybrid Dynamic Systems: is it V-REP a good choice?
Hello Roberto,
your question is very broad. But when it comes to synchronization, you can do everything with V-REP:
- You can synchronize threaded child scripts with the main simulation loop
- Non-threaded child scripts are synchronized by default
- With remotely located controllers, they run in asynchronous mode by default. But you can enable a synchronous mode for them, in which case, the client will be able to trigger each individual simulation step. Have for instance a look at this page.
- You have various types of callback-scripts, that allow you to react to various events (e.g. typically joint controller events) in the exact appropriate time.
