Center of Mass Visualizer data read
Jay
Post by Jay »
Hi all,
I am trying to read the position of the center of mass of my vehicle to MATLAB. I realized that in 'centerOfMassVisulizer' customization script
      if (totalMass~=0) then
		local centerOfMassOfModel={miri[1]/totalMass,miri[2]/totalMass,miri[3]/totalMass}
		local c={centerOfMassOfModel[1],centerOfMassOfModel[2],centerOfMassOfModel[3]}
		local xx=size
		simAddDrawingObjectItem(drawingObject,{c[1]-xx,c[2],c[3],c[1]+xx,c[2],c[3]})
		simAddDrawingObjectItem(drawingObject,{c[1],c[2]-xx,c[3],c[1],c[2]+xx,c[3]})
		simAddDrawingObjectItem(drawingObject,{c[1],c[2],c[3]-xx,c[1],c[2],c[3]+xx})
c[1], c[2], and c[3] are actually the center of mass position. So I was wondering what kind of command I can use in MATLAB side to read these information. Any kind of help will be greatly apprecaited.
Regards,
Jay
Re: Center of Mass Visualizer data read
Hi Jay,
the simplest would be to pack the information needed in a string signal, like for instance:
local data={1.23,3.45,5.67}
local packed=simPackFloats(data)
simSetStringSignal("myData",packed)
On Matlab side, you would then use simxGetStringSignal and simxUnpackFloats.
Jay
Post by Jay »
coppelia wrote:Hi Jay,
Hi Admin,
Thank you for your help, I appreciate it. However, when I followed your tutor to put the code at the bottom of the ''centerOfMassVisualizer" code as follows
visualizeCenterOfMass=function(baseHandle,size)
	local allNonStaticShapes={}
	local miri={0,0,0}
	local totalMass=0
	for i=1,#allNonStaticShapes,1 do
		local mass,inertia,com=simGetShapeMassAndInertia(allNonStaticShapes[i],nil)
		miri[1]=miri[1]+mass*com[1]
		miri[2]=miri[2]+mass*com[2]
		miri[3]=miri[3]+mass*com[3]
		totalMass=totalMass+mass
		local xx=size
		-- Add a banner:
		local bn={centerOfMassOfModel[1],centerOfMassOfModel[2],centerOfMassOfModel[3],0,0,0}
		simRemoveBanner(bannerHandle)
		bannerHandle=simAddBanner(string.format("Total mass=%.3f Kg",totalMass),0,sim_banner_bitmapfont+sim_banner_overlay,bn,-1,black,purple)
		centerOfMassOfModel={0,0,0}
		simAddDrawingObjectItem(drawingObject,nil)
		bannerHandle=simAddBanner("Could not find dynamic objects..",0,sim_banner_bitmapfont+sim_banner_overlay,{0,0,0,0,0,0},-1,black,white)
[b]local centerOfMassData={c[1],c[2],c[3]}
local stringData=simPackFloats(centerOfMassData)
simSetStringSignal("centerOfMass", stringData)[/b]
I cannot read the data to MATLAB. But when I do test by putting the following code in the following way,
		local xx=size
		-- Add a banner:
[b]centerOfMassData={1,2,3}
I can read [1 2 3] in MATLAB. I was wondering how can I fix this problem.
Regards,
Jay
Is there any error message in the status bar when you run the simulation? There should be an error saying that the variable c is nil or something similar. It is important not to ignore error messages. Otherwise you will never get your code right.
You basically need to put the code in the section where c is still in scope, otherwise c is undefined (i.e. nil)
