child script, write forceVector to file
xelda1988
Post by xelda1988 »
I have code from the following child script, which accesses a force sensor:
-- Put some initialization code here
-- opens file to write forces into
local file = io.open("/home/test_force_output.txt", "a")
--handle for force sensor
forceSensorHandle=simGetObjectHandle("Force_sensor")
counter = 1
while (simGetSimulationState()~=sim_simulation_advancing_abouttostop) do
result, forceVector,torqueVector=simReadForceSensor(forceSensorHandle)
--print(counter)
file:write(counter*0.05)
file:write(",")
file:write(forceVector[1])
file:write("\n")
counter = counter + 1
file:close()
I get the following compilation errror:
Lua runtime error: [string "SCRIPT Force_sensor"]:53: bad argument #1 to 'write' (string expected, got nil)
Simulation paused.
What's the problem, seems like there is nothing written to the variable forceVector?!
Please Help
Re: child script, write forceVector to file
As a quick guess: simReadForceSensor will return a status value (i.e. result) that is bit-coded. If bit0 is not set, this means the call didn't succeed. This usually happens if simReadForceSensor is called before the first call to simHandleDynamics (i.e. most of the time in the first simulation pass). If your force sensor is set-up with a filter, then you might have to wait a few passes until the sensor measured enough values for the filter to produce an output (here again, check for bit0 of the first returned value).
Just check your status value. Only if bit0 is set will there be a second value returned (i.e. forceVector).
xelda1988
Post by xelda1988 »
That seems to be the problem, because I already wrote the bit coded variable to the output file and the value jumped to 1 after about 500ms.
Thanks for the super fast feedback :)!
alexander_the_great
Post by alexander_the_great »
Hello I have a question on this matter. I am trying to write to a file in Vrep and it is giving me this lua error:
"Lua runtime error: [string "SCRIPT scriptRunner"]:213: attempt to index global 'telemFile' (a nil value)"
my filename is telemFile and I store the file and the scene inside the vrep folder that comes with downloading vrep.
But I cannot seem to get it to work. I have also tried storing the telemFile.txt and the scene in Desktop but that didn't work either. How did you do it?
Thanks.
Eric
Post by Eric »
well to simply write a file in LUA
name = "toto.txt"
file = io.open(name, "w")
file:write("Hello World")
file:close()
to read a file that is inside v-rep folder
name = "toto.txt"
file = io.open(name, "r")
print(file:read())
file:close()
The scene does not need to be saved inside v-rep s folder.
Eric
