followPath ROS service
formica
Post by formica »
Dear coppelia,
my goal is implementing a ROS service, called 'followPath' to follow a precomputed path.
This is the code, contained in a threaded child script, that I call using simRosCallScriptFunction:
followPath=function()
	while simGetSimulationState()~=sim_simulation_advancing_abouttostop do
	targetObj=simGetObjectHandle('Quadricopter_target')
        pathObj=simGetObjectHandle('Path')
        scriptHandle=simGetScriptHandle('Quadricopter_base')
        speed=simGetScriptSimulationParameter(scriptHandle,'speed',false)
        acceleration=simGetScriptSimulationParameter(scriptHandle,'acceleration',false)
        simFollowPath(targetObj,pathObj,3,0.1,speed,acceleration)
... but apparently nothing happens.
Do you have any hint?
Regards
Roberto
Re: followPath ROS service
Hello Roberto,
the best would be to use the new Ros interface, which is much more flexible, extendable and naturally duplicates the ROS C++ API.
But with the old Ros plugin, you should have your function defined as follows:
followPath=function(inInts,inFloats,inStrings,inBuffer)
    local outInts={}
    local outFloats={}
    local outStrings={}
    local outBuffer=''
    return outInts,outFloats,outStrings,outBuffer
