Throwing object
GodANU
Throwing object
Post by GodANU »
Hi there,
I am trying to throw an object from somewhere into a basket. While this is happening I'd like to observe this object with Kinect. But unfortunately, I could not find anything to throw as an object and also I do not know how to do this animation even I would have an object.
I am very new in V-REP. I would be appreciated a lot if someone could help me fill those blanks in my mind.
Thank you,
Re: Throwing object
you can add a primitive sphere (i.e. a pure sphere) with [Menu bar --> Add --> Primitive shape --> Sphere]. This could be your object.
Then, you can apply an initial velocity to that sphere by attaching in a non-threaded child script like in following example:
    h=simGetObjectAssociatedWithScript(sim_handle_self)
    simSetObjectFloatParameter(h,sim_shapefloatparam_init_velocity_z,10)
Above will give to your sphere an initial velocity in the Z-direction of 10 meters/seconds. So your sphere will jump up and eventually come down again.
GodANU
Re: Throwing object
Post by GodANU »
Thank you sir
govind458
Re: Throwing object
Post by govind458 »
Hey,
I was working on a similar project where the gripper can close and pickup an object before throwing it into a basket. But, we are stuck after picking up the object. Can you please help me with understanding in how to throw an object!
Thank You
Re: Throwing object
Throwing an object is quite difficult, even if it doesn't appear so. The point is that the moment where the object has to be released is crucial. Also how the object is released.
I would highly recommend to use a pseudo gripping mechanism where you attach the object via a simple force/torque sensor. Then, to release it, simply set the parent of the object to -1 (sim.setObjectParent).
govind458
Re: Throwing object
Post by govind458 »
Can you please guide me along the processes I should follow by using the pseudo-gripper mechanism? For come reference we are using a phantom pitcher robot with a RG2 Gripper to throw a cube present in air, after making it move along a certain path
Re: Throwing object
simply remove the last 6 object in the robot's hierarchy. Then attach a force/torque sensor to object PhantomXPincher_link5.
Then, you can simply programmatically attach/detach a dynamic shape to the force/torque sensor via sim.setObjectParent.
govind458
Re: Throwing object
Post by govind458 »
Oh I see. We were thinking along those lines. The next issue we faced was, we didn't know how to make the robot do a task such as open gripper/close gripper DURING THE EXECUTION OF THE PATH. Is this possible?
Re: Throwing object
Yes, this is possible. It depends how you are doing things. If you are following a path in a blocking manner, then you can't do it from that script. You'll have to handle the detachment from another script, or handle everything inside of a non-threaded child script.
govind458
Re: Throwing object
Post by govind458 »
So then, how do we do it during the path execution?
