Robot movement and linear velocity
makbut
Post by makbut »
Hello! I am running some simulations on VREP and I have one question regarding the movement of my robot.
I am using the Pioneer-P3dx robot. The robot subscribes to the /cmd_vel topic. I am using the teleop_twist_keyboard in order to publish messages to that topic and then the robot moves according to the keystrokes. The callback function which is called upon subscription is the following:
    local wheel_radius = 0.2
    local wheel_separation = 0.5
    local speed_left = (msg['linear']['x'] + msg['angular']['z'] * wheel_separation/2)/wheel_radius
    local speed_right = (msg['linear']['x'] - msg['angular']['z'] * wheel_separation/2)/wheel_radius
    simSetJointTargetVelocity(motorLeft, speed_left)
    simSetJointTargetVelocity(motorRight, speed_right)
I observed that the wheel radius has an impact on the movement. For example the bigger is the radius, the bigger linear velocities values, I can provide and the robot can move in straight line. If the radius is small, then the robot is not moving in straight line and it does a weird curved movement.
For example, for linear velocity of 2 m/s and radius 1 meter the robot moves straight, but if radius is 0.1 meters it does not move straight. Instead it does a curved motion.
I think that there is something with the physics that I miss, could anyone explain?
Thanks in advance!
EDIT: The original post about the simulation step was inaccurate. I figured that out!
Re: Robot movement and linear velocity
not sure I understood your problem correctly.
Your robot could suffer under the effect of slipping, or too small torque. The best is to switch to another physics engine and see if the results are similar or not. That can also give you a clue of what is going on.
If you can reproduce the problem in self-contained scene, the please post it. It is often faster to look at the scene than to try to guess the problem.
makbut
Post by makbut »
Hi!
It seems the problem is solved or it never existed. It was just a matter of understanding the physics.
Thanks for the reply.
WillC
Post by WillC »
Thanks makbut!
For anyone else, here's the full child script for a standard Pioneer 3DX model to receive geometry_msgs/Twist topic on the /cmd_velfrom ROS such e.g. rosrun teleop_keyboard teleop_keyboard.
You may want to add scaling factors and/or limits for linear and/or rotational acceleration and velocity on top of this.
-- This is a very simple EXAMPLE navigation program, which avoids obstacles using the Braitenberg algorithm
function cmd_vel__callback(msg_)
    -- Apply the received image to the passive vision sensor that acts as an image container
    msg = msg_
    print(msg_)
    usensors={-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1}
    for i=1,16,1 do
        usensors[i]=simGetObjectHandle("Pioneer_p3dx_ultrasonicSensor"..i)
    motorLeft=simGetObjectHandle("Pioneer_p3dx_leftMotor")
    motorRight=simGetObjectHandle("Pioneer_p3dx_rightMotor")
    noDetectionDist=0.5
    maxDetectionDist=0.2
    detect={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
    braitenbergL={-0.2,-0.4,-0.6,-0.8,-1,-1.2,-1.4,-1.6, 0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0}
    braitenbergR={-1.6,-1.4,-1.2,-1,-0.8,-0.6,-0.4,-0.2, 0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0}
    v0=2
    sub=simExtRosInterface_subscribe('/cmd_vel', 'geometry_msgs/Twist', 'cmd_vel__callback')
    simExtRosInterface_subscriberTreatUInt8ArrayAsString(sub) -- treat uint8 arrays as strings (much faster, tables/arrays are kind of slow in Lua)
    msg = {}
    if msg ~= nil then
