Simulink and V-REP
Simulink and V-REP
Hi!
I am new to V-REP and I was wondering if it was possible to use a Simulink file through MATLAB to run the simulation in V-REP. Any input would be greatly appreciated!
Thanks!
Sarah
Thanks!
Sarah
Re: Simulink and V-REP
Hello Sarah,
This should be no problem. Have a look at the remote API, its Matlab binding and its Matlab API. From there, there should be no difficulty to refer to those API functions from within a Simulink file, have a look here for instance.
Thanks so much!! All of those files were very helpful! I had another question. My simulink file models the motion and dynamics of a quadrotor. Do you know what the best way to send the information calculated from MATLAB to V-REP and have the simulation be controlled by the simulink? Also, should this portion of the code be added after the simulink model has done all of the calculations?
Thanks!
Sarah
Thanks!
Sarah
Hello Sarah,
You can do the high-level control of the quadrotor via Simulink and the remote API. Typically you can send data to your objects/models with simxSetIntegerSignal, simxSetFloatSignal, simxSetStringSignal, or simxAppendStringSignal.
For the low-level control (which has to happen synchronously with the simulation loop and much faster), you should use a child script if possible. You could also do it via the remote API, but in that case you should enable the synchronous mode with the functions simxSynchronous and simxSynchronousTrigger. But your simulation will run slowlier (since after each simulation step it will wait for a trigger signal).
Thanks!! I'm attempting to use the simxSetIntegerSignal to control the x position of the quadrotor, however when I run my Simulink, I get this error about the remapi.m file: "Code generation does not support the 'delete' method. Handle objects are only destroyed when program execution ends, and destructors are never called." Below is my code so far, I modeled it off of the simpletest MATLAB file found in the V-REP programming folder. Any ideas of what could be missing or incorrect?
Thanks!
Sarah
Thanks!
Sarah
function startvrep(x,y,z,phi,th,psi)
disp('Program started');
vrep=remApi('remoteApi','extApi.h');
clientID=vrep.simxStart('10.18.6.99',1,true,true,5000,5);
if (clientID>-1)
[errorCode]=vrep.simxLoadScene(clientID,'C:\Users\Sarah\Dropbox\ME 791\quadrotor_scene.ttt',10,vrep.simx_opmode_oneshot_wait);
[errorCode]=vrep.simxStartSimulation(clientID,vrep.simx_opmode_oneshot);
[errorCode]=simxSetIntegerSignal(clientID,'x',x,vrep.simx_opmode_oneshot)
% [errorCode,minimumDistance]=vrep.simxReadDistance(clientID,,vrep.simx_opmode_streaming):
% [errorCode,detectionState,detectedPoint,detectedObjectHandle,detectedSurfaceNormalVector]=vrep.simxReadProximitySensor(clientID,,vrep.simx_opmode_streaming);
if (res==vrep.simx_error_noerror)
fprintf('Number of objects in the scene: %d\n',length(objs));
fprintf('Remote API function call returned with error code: %d\n',res);
vrep.simxFinish(clientID);
disp('Failed connecting to remote API server');
[errorCode]=vrep.simxStopSimulation(clientID,vrep.simx_opmode_oneshot);
vrep.delete();
disp('Program ended');
Hello Sarah,
could you try to remove the vrep.delete(); instruction and see if there is a difference? Or possibly also remove the delete function in the remApi.m file just to see?
Are you generating any MEX-file?
I have commented the two delete functions and it seems that MATLAB doesn't recognize the command remApi (error: "Undefined function or variable 'remApi'.") I don't think I am generating an MEX-file... could that be the issue?
Thanks!
Sarah
Thanks!
Sarah
Your program looks weird, you should remove the 2 following lines near the end, since at that position the connection has already ended:
(you should only call simxFinish once, and only if clientID was not -1)
also, after loading the scene, your program will prepare to send 2 commands (start simulation and set integer signal) and directly after end the connection with simxFinish. The result is that those 2 commands won't have the time to be sent! (unless you send them with the operation mode simx_opmode_oneshot_wait)
If you run the function from Matlab directly (i.e. not simulink), do you get the same error?
If you run the simpleTest.m function, do you get the same error?
Oh I didn't notice I had it in there twice! I've removed those lines and added the newer operation modes. When I run either of the programs in MATLAB, I receive this error:
I have tried to look up how to implement a mex-setup but I couldn't find anything that explained this. Do you know where I can read about this or how to do so?
Thanks!
Sarah
>> simpleTest
Program started
Error using loadlibrary (line 254)
A 'Selected' compiler was not found. You may need to run mex -setup.
Error in remApi (line 568)
loadlibrary(obj.libName,obj.hFile);
Error in simpleTest (line 21)
Thanks!
Sarah
Sarah,
is it possible that the demo simpleTest.m never worked? From what you are describing, you haven't set-up Matlab correctly yet.
Try typing:
mex -setup
Then allow Matlab to locate installed compilers. Finally, select a compiler.
Make also sure that your Matlab copy is also 32bit (if your Matlab copy is 64bit, you will need to recompile remoteApi.dll yourself in 64bit). Make sure you have carefully read the Matlab section here.
Try typing:
mex -setup
