Control scene objects in VREP through ROS
cjndiaye
Re: Control scene objects in VREP through ROS
Post by cjndiaye »
Hello, yes the object is initially dynamic. I just want to change it in three different positions before it join the box chosen for it.
But in its last position, if I use simSetObjectPosition, the object does not change its position.
Sorry, your question is too specific to your scene. There are many things that could go wrong. Best is to prepare a very simply scene that illustrates the problem, and post it here.
slgrajeshwar36172
Contact:
sim.setJointPosition is not working.can you please help me
Post by slgrajeshwar36172 »
function sysCall_init()
    -- Get some handles:
    joint=sim.getObjectHandle('Joint')
    -- Enable an image publisher and subscriber:
    sub=simROS.subscribe('/joint_topic', 'std_msgs/Float64', 'joint_callback')
    simROS.subscriberTreatUInt8ArrayAsString(sub) -- treat uint8 arrays as strings (much faster, tables/arrays are kind of slow in Lua)
function joint_callback(msg)
    -- Apply the received image to the passive vision sensor that acts as an image container
    print(msg.data)
    --sim.setJointTargetVelocity(joint,msg.data)
    [b]sim.setJointPosition(joint,(math.pi/180) *msg.data)[/b]
function sysCall_cleanup()
    simROS.shutdownSubscriber(sub)
What do you want to achieve by just positing code without any question/comment?
