Can a Joint be a child of a force sensor
avico23
Post by avico23 »
I have a wheel joint and I would like to know the contact force between the wheel and the wall/ground.
What is the correct method to do so.
I will like to read this force in matlab.
ssj
Re: Can a Joint be a child of a force sensor
Post by ssj »
hello
I think you can use the API simGetJointForce for this.
no, you can't. And simGetJointForce will not return the radial force that applies on a revolute joint. See details here.
For that you should connect your joint to an auxiliary mass (non-respondable), itself connected to a force sensor, itself connected to the body of the vehicle.
Or you can use simGetContactInfo. Have a look at the Models/other/contact display.ttm model for details.
