Assigning an Object Handle to Robot's Initial Position.
sradmard
Post by sradmard »
I am trying to publish odom data and the associated tf of my robot in ROS. I am currently publishing my tf for the odom as follows.
transformations[1]=getTransformStamped(modelBase,'base_link',-1,'odom')
simExtRosInterface_sendTransforms(transformations)
However, this would place the 'odom' frame at the world origin. This is not applicable when my robot starting positin is not at the world origin in v-rep. Therefore, instead of -1, I would like to assign an object handle to the robot's initial pose. Is there an easy way to do it through the script without needing to define a stationary dummy frame at the base of the robot?
Thank you so much in advance.
Re: Assigning an Object Handle to Robot's Initial Position.
try with something like:
function getTransformStamped(objHandle,name,relToMatrix,relToName)
    local t=simGetSystemTime()
    local m=simBuildIdentityMatrix()
    if relToMatrix then
        m=simCopyMatrix(relToMatrix)
        simInvertMatrix(m)
    local objM=simGetObjectMatrix(objHandle,-1)
    local objRelM=simMultiplyMatrices(m,objM)
    local p={objRelM[4],objRelM[8],objRelM[12]}
    local o=simGetQuaternionFromMatrix(objRelM)
    return {
        header={
            stamp=t,
            frame_id=relToName
        child_frame_id=name,
        transform={
            translation={x=p[1],y=p[2],z=p[3]},
            rotation={x=o[1],y=o[2],z=o[3],w=o[4]}
So instead of providing the handle of the object you want the data relative to, simply provide the matrix of that object. See the other matrix API functions.
sradmard
Post by sradmard »
Thank you so much for your reply. However, I still believe that the problem is not solved. Instead, I have to manually provide the initial position/orientation matrix of my robot with respect to the world in the child script. I also have to update that matrix every time my robot's initial position/orientation changes. I don't see this being different than creating a dummy frame at the base of the robot and moving it every time the robot's initial position/orientation is different.
I am looking for a way to make it automatic if possible. Is there any suggestion on that?
Should I make that dummy frame stationary and the parent frame of my entire robot, so that every time that I want to change the initial position/orientation of my robot I just change that dummy frame?
Thank you again.
