Set random direction to avoid other ePucks on the scene
DavideIng
Post by DavideIng »
I am coding a scene with two ePucks (the next step is going to have more ePucks) and the main purpose is the following:
When the ePucks are going to be closer than a certain distance (threshold has been fixed before) they have to change direction: in my alghoritm they turn of 90 degrees and then go streight along the new direction.
I would like that the direction of turning is going to be random and to do that I am using the following code:
ePuck One:
local m=simGetObjectMatrix(ePuck,-1)
        local m2=simBuildMatrix({0,0,0},{0,90*math.pi/180,90*math.pi/180})
        m=simMultiplyMatrices(m,m2)
        local e=simGetEulerAnglesFromMatrix(m)
        p = simGetObjectPosition(ePuck,-1)
        p1 = simGetObjectPosition(ePuck1,-1)
        a = (p[1] - p1[1])^2
        b = (p[2] - p1[2])^2
        d = math.sqrt(a + b)
        simWriteCustomDataBlock(ePuck1,'position',simPackFloatTable({d}))
        rand1 = math.random(-1,1)
        rand2 = math.random(-1,1)
        if (math.sign(rand1)== math.sign(rand2)) then
        rand1 = -rand1
        if ( d < 0.3 ) then
        while (e[3] >= 0) and (e[3] < math.pi/2) do
        simSetJointTargetVelocity(leftMotor,maxVel*rand1)
        simSetJointTargetVelocity(rightMotor,maxVel*rand2)
ePuck Two:
local m=simGetObjectMatrix(ePuck1,-1)
        local data = simReadCustomDataBlock(ePuck,'position')
        local d = simUnpackFloatTable(data)
        rand1 = -rand1
        if (d[1] < 0.3) then
        while (e[3] >=-math.pi ) and (e[3] <=-math.pi/2) do
The problem is that the statement:
        rand1 = -rand1
Doesn't work as desired, the error returned is the following:
Lua runtime error: [string "SCRIPT ePuck#0"]:67: attempt to call field 'sign' (a nil value)
The purpose of this statement is to not allow the variables maxVel*rand1 and maxVel*rand2 to have the same sign otherwise the ePuck doesn't turn.
Can anyone explain to me how to write the code with the purpose explained above without retrive error?
Thanks in advance.
Davide
DavideIng
Re: Set random direction to avoid other ePucks on the scene
Post by DavideIng »
Fix it.
        if ((rand1 > 0) and (rand2 > 0)) or ((rand1 < 0) and (rand2 < 0)) then
        rand1 = -rand1
